- Sep 24, 2001
- Currently Nowhere
Meh. I went from Socket A (AMD) to 775 a couple of years ago. It will be another 3 years before I can afford to think about another rig, let alone care about what new sockets there will be.
For Socket 1366, we still have CPU's yet to be released.
Also like I said, 3 years and not having to change my motherboard, I am ok with that. The Fact Intel or AMD cant make a faster product for me for at least 3 years, I am not.
Also 6 Generations have not passed in Socket 775
P68 aka P4 is a 7th Generation CPU
Core 2 is a 8th Generation
Core i7 is a 9th.
I have no idea how you are getting 6 generations...
Also, How many Chipsets/ Motherboards for Socket 775 are still supported or work with Prescott all the way to a Core 2 Quad?
I think you are over ratting the platform.
A 6 year old motherboard/chipset will not be cutting it today.
Current Chipsets that will not work would be
8XX series
9XX series are hit and miss, but giving the benefit of doubt we will say a
945 or 965 board is still relevant, so a 2006 release, thats 2 years off your timeline right their.
Prescott and Core/Core2 are the two architectures.
Note the period between "Core2" and "Core2duo".
Core2 was based closely on Core, which was based loosely on Pentium M, which was based on P3, if you want to be exact.
Core i7 is a 9th.
Not even close, you have to pay attention to the numbers, Im so glad you went there.E7500 and E8400 are the same generation.
E7xxx is an E8xxx with some of the cache cut out, and running on 266fsb instead of 333. The core itself is identical.
Same with e5xxx(more cache cut out, 200fsb) and the 45nm e6xxx(266fsb, more cache cut) too.
I would say that's 7 different generations if you count all the names of the cores and there numbers. It was much eaiser with pentium 1,2,3,4 generation change.At leastfivefour:180nm(180nm was 423/478), 130nm, 90nm, 65nm, 45nm.
P4 - Willamette 180nm, Northwood 130nm, Gallatin, Prescott 90nm.
Core 2 - (Conroe. Allendale. Kentsfield.) 65nm (Penryn. Yorkfield. Wolfdale.) 45nm
Yes I pointed that out above the architecture changeesSome of you guys are really confusing what constitutes a generation.
A die shrink does not
A Core variety/variant does not.
[fact]The underlining architecture of the core is what defines a generation[/fact]
[fact]So is the next generation, it's variant of the last generation they just do die shrinks and change the instructions and Cache that is architecture change [fact].What do you think instructions, Cache and die shrink are, maybe there just playing around. so you can't base generation on what you said above, remember intels tick tock.It does not matter what ever you are defining, if its anything other than an architectural change, it is not a different generation.
It doesn't matter if you add cache/Cores.
Shrink the die, or even add new instructions.
That CPU will still remain a variant of that said architecture and thus generation family.]
CPU Generations based on the the x86 architecture are as follows
1st Gen: 8086/8088
2nd Gen: 80286
3rd Gen: 80386
4th Gen: 80486
5th Gen: P5/P54/P54C/P55C
6th Gen: P2/P Pro/P3
7th Gen: P68 (Pentium 4)
7/8th Gen: Yonah (Core)
8th Gen: Core (Core2)
9th Gen: Nehalem (Core i 3/5/7/9
10th Gen: Sandy Bridge
I may have missed on or two derivatives in their, but those are the only generations of CPU's that exist.
@wingman99
The Gigabyte GA-945PL-DS3 (rev. 2.0) linked is a board from LATE 2006.
You would be lucky to have found it in stores Q4 06. It will have its 4th Birthday in Nov 2010
You may count 6 generations of CPU's but it is in fact 2 generations that this board supports.
@petteyg359
Like i said above a die shrink does not constitute a new generation nor do any of the small variants of the core.
There all variants, they just change a little of this, little of that add this add that, more instructions change the number of pipes, registers, Cache, add a new Cache new instructions,Better Branch Prediction, die shrink. My point is they always build from the past and some times they use the past instructions because it works better with the new die shrink, like the p2- p3 instructions used for Core 2 also HT from p4 on the i3,5,7, series with AMD's on-die memory controller.By that logic, you need to remove 8th gen from that list, because it is a "variant" of Pentium 3.
[Fact] A new generation is a new product for sale by Intel that supersedes the last product they sold,tick tock.
It's not about how much progress intel make when they sell a new cpu, it's just a new generation from the last design there all variants from intel's CPU's build from there last architecture, you have it completely wrong, it's about selling and designing CPU's and each new one that supersede the old is a generation change you just cant pick and chose what cpu is a genration change becase of progress or the lack there of.That is completely wrong. You are not pointing out architect changes at all.
The P5 was a revolutionary change over the 486, as was the P5 over the 486 as was the P6 over the P5, ect, ect.
The only one i might somewhat agree with you was the 386 to 486.
This was basically adding the 80387 onto the 80386 die and wholla you have a 486. That is also completely ignoring that multipliers made their 1st appearance at this point in time.
Anyhow, lets not jump back to far and talk about the P68, once again it is nothing at all like the P6. I would call them the differance between night and day actually. With one favoring a short pipeline with a high IPC, witch subsequently prevents a high clock rate. The other, a long pipeline with a low IPC allowing the clock rate to skyrocket.
However this is were things start to confuse people as things start to blur after P68 as the P68 was far to ambitious. Power and leakage got way out of control and we never did see the 10Ghz promised due to this fact.
they took a step back and moved back towards the P6 architecture as it was VERY power efficient and powerful per watt.
So we ended up with a sort of hybrid fusion of the two techs to get the best of both worlds. Intel was building on that until its finally moved to Nehalem.
They are two generations didn't you watch the advertizing back then, there was a architecture changes and it was great because I had all 3 p1 p2 p3.No its not.
Best example is Pentium Pro, Pentium 2 and Pentium III
They are all the same generation..
Intel has always been in a cycle for new product's yearly, although it has slowed down, tic tock is just slang, it has been around from the begging.Lastly, tick tock is a new concept at Intel that was announced in 2007 to state they were moving to a new generation of processors. AKA the move to Nehalem. As such it doesnt apply to anything other than Nehalem and newer CPU's.
You are now describing Marketing.They are two generations didn't you watch the advertizing back then, there was a architecture changes and it was great because I had all 3 p1 p2 p3.
AMD has a different approach and in a way I think it could be hurting them. Personally I look @ where the money comes from and the BULK IS OEM!!!! Who really cares about the enthusiast? The aftermarket parts sector, GFX card companies, memory, HDD,............ So AMD may be making a mistake by sticking with compatibility.
Sorry but the change is good business.
I disagree. Hypothetical situation: If you own a computer shop, and you've just ordered (in bulk, because it's cheapest, and therefore most profitable in the end) 1000 socket 775 motherboards. You've also ordered 1000 Q9400 CPUs. Most of your client base is somewhat computer literate, and they always want the latest technology, if not the best. They are aware that Intel has just released i7. Now, you're stuck with 1000 boards and CPUs that your customer base doesn't want. If you had gone with AM2+ boards and Phenom 9650 CPUs, and your customers decide they want the latest Phenom II X4 CPU, you can just order a new batch of CPUs and stick them in the old boards. You're stuck with 1000 old CPUs, but you didn't have to write off the boards.
