- Sep 27, 2003
I'm folding on 3 different machines, username godman114 and obviously Team32. They are all dual-core machines with WinXP Pro SP3. No, I'm not changing the O/S so please never mention that. I'm very happy with XP.
Here are my machines:
Now with that said, I installed the systray version and I love how easy it is to use. Problem is systray runs on one core, so what I did was copy the FAH folder in program files and pasted it somewhere else, renamed the folders to Folding2@home and Folding2@home-x86. Then I renamed the 2 application files (exe files) to [email protected] and viewer2.exe, so that I can tell them apart in task manager.
I then made shortcuts to [email protected] and [email protected] and put them in the startup folder for windows, so that they should automatically start when I turn on the machines.
Few concerns/questions:
- My HTPC - 3.0GB DDR2-800 (512mb shared video), AM2 BE-2350 @ 2.8ghz brisbane @ stock volts/cooling (I wonder if I should upgrade the cooling since I'm running it 100% 24/7)
- My Home Server - 2.0GB DDR2-800, AM2 4000+ X2 2.1ghz stock brisbane (maybe I'll OC it someday)
- My Gaming/Main PC - 2.0GB DDR3-1600, Intel Core2 4.0ghz watercooled E8500 E0 @ ~1.35v
- Do I have to use a different machine ID on every single machine, or is that just for each machine? For example, can I do machine ID 1 and ID 2 for each core on each machine, or do I have to do ID1 and ID2 for the first PC, then ID3 and ID4 for the 2nd PC, and ID5 and ID6 on the 3rd PC??
- Kaspersky is awesome but I can't stand how annoying it is. I have it on my MAIN/Gaming machine (see specs above) and I thought I got to the bottom of the issue with Kaspersky. It kept putting FAH to sleep!! Anyway, I almost want to get rid of Kasp b/c of all the problems and I can't seem to understand it too well, but I thought I fixed it last night b/c FAH started working again. What I did was add FAH and FAH2 to the exclusions (I really hate how Kasp will warn you that something was blocked and when you hit to see the report it doesn't let you UNDO the blocking)... anyway, today (and right now) I get on the machine to see both FAH systrays are on (and not sleeping) but my CPU usage is at 0%!!!!!!!! What should I do? I saw in the log file this here (just copied the bottom-most part):
[19:56:20] + Attempting to get work packet
[19:56:20] - Connecting to assignment server
[19:56:21] - Successful: assigned to (171.64.122.139).
[19:56:21] + News From Folding@Home: Welcome to Folding@Home
[19:56:21] Loaded queue successfully.
[19:56:21] - Couldn't send HTTP request to server
[19:56:21] + Could not connect to Work Server
[19:56:21] - Attempt #8 to get work failed, and no other work to do.
Waiting before retry. - Is it stupid to run the systray twice the way I did? Is there anything else I should be doing?
- Can I fold with onboard video or is that dumb to even ask?
- Can I fold with an HD4870/4890? I'm sure these questions are answered somewhere but I really don't have the time or patience to read everything. Yes, I'm feeling lazy as usual.
- Should I make a password? I'm just connecting as godman114 and team32...
