QuietIce
Disabled
- May 7, 2006
- Anywhere but there
cpuNB (not the NB chipset) should be running 1.175-1.250v (that's for the X4 and I think we're all assuming it's the same for the X6). If you make sure it's the cpuNB voltage (sometimes labeled with VID or VDD) you can raise it to 1.20v and you should be able to increase your cpuNB speed up to that 22-2400 MHz.
I wasn't dissing what you did with cable management - not at all - I just saw all those nice, neat holes in the backplate and "fondly" recalled the taping/zip-ties, routing, and hole drilling I did with my first big build. And you're very right, a LOT of new people just sort of let the cables run where they fall, so-to-speak. You did do a good job not only routing the cables but having the forethought to buy the right case to begin with ...
