- Dec 8, 2005
- Houston, TX
fuzzba11 said:
lol, didn't even notice that. The spring and the nut are suppose to be on the other side.
fuzzba11 said:
while it already does, order shouldn't matter much at all.Lee_Kay said:You might want to change the tubing so the pump outlet goes to the CPU block not the GPU block.
there's about a .5c fluctuation in the loop with a very hot pump & a nice OC. The OP is running a DDC that adds almost no heat to the loop. The order will make VERY little difference.Lee_Kay said:it does matter. Pumps have operating temps. So if you go rad - pump - cpu - gpu - rad. You ensure you have the coolest possible temp going into your pump.
did you use tap water!?! You should NOT have deposits in your loop at all. I'd also hope that your water isn't 60c... but all this is besides the point. The water temperature in the loop fluctuates very little and order matters very little; it's more important to use the least tubing possible.Lee_Kay said:its not about adding heat to the loop. I had been running my setup since November and I changed my system round this week and I took the time to stip and clean my pump. It had lime deposits on the inside of the pump spindel in just 3 month. That in its self creates heat resistance. I cleaned it all up and put it all back together. But thats still not my point. When you have 60c water going into your pump its not a very effective lubricator and will cause some wear.
Yes, I'd say you do, so by anyone's account you're fineRIG RIDER said:Actually I think i have the optimal setup for my temps.
-Pump(MPC-350 minimal heat output)
-Rad(dissipates heat from pump before going to CPU
-CPU(Apogee low restriction good heat transfer)
-GPU(NV-68 great for my 6800Ultra)
& back to the pump.
I've probably hit that before, but it should really never happen. I just hit my fan controller by accident one night and the fan turned off. I woke up to a CPU temp of 113c! The radiator was so hot that it burnt me when I touched it. I'm lucky it didn't melt the tubing or kill the CPU.otogrim said:The way you have things set up looks good to me. And I doubt the water in the loop would ever get to 60c.
BS.Lee_Kay said:its not about adding heat to the loop. I had been running my setup since November and I changed my system round this week and I took the time to stip and clean my pump. It had lime deposits on the inside of the pump spindel in just 3 month. That in its self creates heat resistance. I cleaned it all up and put it all back together. But thats still not my point. When you have 60c water going into your pump its not a very effective lubricator and will cause some wear.
