Edit: Solved.
Hello,
I've recently purchased my first Sata drive, a bare WD Caviar Black 640GB 3.0gb/s from Newegg. The problem is, I can't use it. I'm hoping that someone can help me discover if the issue is on my end or if the HD is dead.
My specs
Windows 7 SP1
Asus/(HP OEM) Amberine A8AE-LE bios version 3.13
AMD Athlon 64 3700+ 2.2ghz
1gb ram
Quantum Fireball lct 30GB on IDE (Working, Windows Disk)
WD Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s (Not found in Windows)
$2 Ebay Sata Cables
The only evidence of life I've seen from this drive is its continuous appearance in the bios. I've searched for it under disk management in Windows 7. I've tried to format it with the Windows 7 installation disc but it isn't listed as an installed drive. I tried to format it with a Windows XP installation disc (got error 0x80070484 after it presented the drive for install), I've also tried to format it with Easus partition manager which didn't recognize it and a Kubuntu Linux dvd that recognized the WD disk then gave an error saying it the format had failed. I've tried uninstalling all the cables from the motherboard and drive and reconnecting them, trying the 2 possible Sata ports on my mobo 2-3 times a piece. I've tried removing my IDE drive from the computer altogether, somehow causing errors and bad sectors, alas, the damn WD drive is a no-go, connected to the motherboard with no connectivity whatsoever.
The only options I haven't exhausted include updating my bios, asking a friend to test it for me in their computer, and RMA. Any ideas or suggestions would be appreciated greatly.
Hello,
My specs
Windows 7 SP1
1gb ram
$2 Ebay Sata Cables
