Newb OC needs some help( more help needed)
Hola, Im a new person to the forum and to OC in general. I put together a new computer recently using the ASUS P4C800- E deluxe, a Pentium 4 3.0c, 2 sticks of 512 Corsair DDR 3200C2PRO / XMS 3200 memory, and a new Zalman Heatsink fan combo CNSP7000A-Cu. I am using a Xaser III case with its stock 7 fan setup. My PSU is a Thermaltake Silent PurePower Butterfly 480 Watt.
I have tried using the onboard OC feature and from what I have read on these forums, its better to manually input in OC settings. I could use some help on what to try setting the bios at for a stable consistant OC speed. I dont need to push the computer to its limits and would just like to squeeze some stable performance out of this setup. Any help on what I should set the board to would be greatly appreciated.
