- Jan 27, 2006
Hi guy's well i got bored and i was screwing with my clocking's and wanted to get it stable at 3.6 GHZ and have my ram at 1080mhz in dual channel.
so far with the settings (pictures below) im able to boot into windows fine. i run Orthos (Large FFTs or Blend) and it will last about 8 mins then ill get an error on one of the cores.
same with Prime 95. with small FFTs it lasted half an hour. i ended it to test the large FFTs and blend tests.
i would like to tweak my settings (voltage or clockings) to get this stable for gaming and ripping blu ray movies to MKV files (takes me a good 12 hours to encode them in 1080P mkv files so needs to be stable
I have 4 Dimm's (1GB Dimm) of this ram. for refferance of what stock should be)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145043
here are my settings. lmk what you guys think
Notice here that 1:1 ratio is 900Mhz but my ram is 1066? am i just reading something wrong here? this is not the setting i have now i just took this picture to ask if the ram is being read right or not
Current voltages
What my monitor voltage says
and my CPU settings
Current voltages
and my CPU settings
