Ok, I have been hitting my head at this for a while and can not figure the reason out.
I have a x2 B550 that I had unlocked to all 4 cores stable on windows 7 64 bit stable for around 2 years now with no issues so I know the cores work fine. I recently upgraded the computer on windows 8 and for some reason the install would fail or once you got into windows you would have odd stability issues such as zip files corrupting or random windows 8 components failing(in general anything that relies on a packaged file has issues) I even reinstalled 7 and yes the unlocked cores work fine perfectly stable, but not in windows 8.
I actually can not run CPU-z or speedfan with the cores unlocked as they will freeze when they try to detect settings. I can actually turn of ACC mode and the computer works perfectly in windows 8 with no issues, but enable ACC mode and windows 8 freaks out.
The system specs are a X2 B550 black edition CPU with MA770T-UD3P motherboard, 8gb of 1033 OCZ memory. The Bios is F5 was thinking about updating it next.
Well, if anyone has seen anything like this let me know, I really love the improved stability of windows 8, but the fact that I can not unlock the cores is driving me insane.
I was able to run EasyTune with the cores unlocked and I can put up some screenshots of it.
