- Dec 25, 2004
VERIFIED WORKING!!
This guide is for Team 32, to show how to mine FLDC to help support our obsession and pay for the electricity and hardware costs.
There are two different coins that can be mined while folding. Curecoin and FoldingCoin. Curecoin requires you to be on their team, so we won't be doing that. FoldingCoin should be minable for any team, and pays out more than Curecoin most of the time as well.
There are currently only 2 exchanges that trade FoldingCoin. Poloniex and Bittrex As of the writing of this guide, Bittrex is not taking new users, and Poloniex is having some issues with some accounts. I would only transfer about 1/4 of your monthly payouts at a time to Poloniex until they get their support to an acceptable level.
The way this works is you have to first get a Counterparty Wallet set up. Go to https://wallet.counterwallet.io/# and click on the "Create New Wallet" button. It will create a wallet and generate a 'passphrase' for you. The passphrase is 12 random words. COPY THEM DOWN AND SAVE THEM!! If you lose them, you will not be able to get back into your wallet. Once you've done that, check the box that says you've saved your passphrase and continue. When you are logged into your wallet, there is an option to create a shortcut/favorite with a password. If you use that link to open your wallet, you can use a shorter password than the 12 word passphrase. If people have a hard time finding this, I'll go through the process and take screenshots.
Once you've created the wallet, the next step is you have to change your Folding Username. You can use whatever you want at the beginning, but then you need to have _ALL_(wallet address) to end it. For example, I'm using torin3_ALL_1K91apgu4f5M26DrYL79Mpa7dhVfmBx4Xo
So to be clear, the name you need to use is whatever you want, underline, ALL, underline, wallet address.
The downside for long term folders is you have to use the different name. If you use the same passkey, you can still track all your points folded by you. And that is what HayesK and I are both doing.
Now, at this point you should have created a wallet, and changed your username to the correct format.
Now...we wait.
FoldingCoin only pays out once a month on the first Saturday of the month. They will track all the points you get and allocate FLDC based on the amount of work you have done. Running 8 cards, mostly 1080Ti cards has been getting me about 27K FLDC a month.
Now when you get your coins deposited in your wallet, you'll need to get need a small amount of Bitcoin to actually transfer it out of the wallet. The less you use, the longer the transfer is likely to take. My recommendation is to buy a small amount of Bitcoin at Coinbase and then transfer it into your Counterparty wallet. After the first time, when you exchange your FLDC for Bitcoin, save a little bit and send it back to the Counterparty wallet for future transactions.
FoldingCoin uses the Bitcoin blockchain for its transactions, so you will have to deal with the fact that Bitcoin transactions run on the slow side.
EDIT: Poloniex delisted FLDC. Bittrex is the only choice now.
EDIT: Bittrex delisted FLDC, current working exchange:
https://www.chainrift.com/
Now...we wait.
