He's a good one for ya the bios update for the Mrs600m won't install it comes up that the current isn't a award bios and when you look at the bios that's on the mobs it's a phoenix one now that's strange and might exsplane why this is going wrong as the mobs has ms 7326 printed. On it but cpuid says it's a Mrs600m could be a mistake on msi part and the wrong bios has been installed on the wrong mobo in the wring machine. Check ya mobo and see what's printed on it . But the biggest mess up of all is msi don't recognise the ms7 mobo. Number. Lmao I think I might have to get a new mobo
You can get a second-hand, but newer, board that supports the CPU you are now using. They shouldn't cost much.
But before chucking the present board out the window why don't you experiment with it. What I had in mind was flashing the BIOS from another computer brand for the MRS600M mobo. In your case I think that would be MSI. If you brick the mobo, it's going out the window anyway. Who knows. It might work.
Hi,Iv tryed searching MSI for a bios with no luck,..
Try searching for phoenix bias updates might be worthy sniff
I am using the hd5450 model same card ascu but it's got 1 gig onboard andvi think the gpu isca little faster but the same card it's running on a core2 duo 2.4
