- May 14, 2005
Well My wife is getting her own computer build. It was only a matter of time, watching me having fun and enjoying my custom rigs. I'm basically giving her my backup rig thats in my sig.
NF3Ultrad D socket 939 with AGP. The 3500 clawhammer CAA2C 0506BPMW chip noted for awesome overclocks. 1 gig. of OCZ EL Plat. Rev2, 200gig seagate sata II, ATI X800XL. Powered by a Antec 550 TP 2.0
Heres the the way it's currently setup
After a gruelling month or so of looking at computer cases, she decided on this one
Kingwin SK-523 Silver ATX Mid-Tower Case with Clear Side, Front USB, Audio and SATA Ports.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1799773&CatId=32
Actually case inteior is pretty nice. 120mm front and rear. and tooless setup
Coler Scheme PINK UV & PURPLE UV
Front pannel lites will be changed to Pink led's. And of course UV pink sleeving. 120mm case fans will be replaced with clear 120mm fans and sprayed them with this
http://www.performance-pcs.com/cata...=20664&zenid=aa25e4157291e4f58c6b21956fe3acb2
And detail the inside of the case and parts of the motherboard with some of this
http://www.performance-pcs.com/cata...d=2764&zenid=aa25e4157291e4f58c6b21956fe3acb2
And some purple glowwire for around the case window
Will be using mirror tape on the floor and sides of the case inteior. heres a pic of mirror tape inside a case
Case has a fantastic metalflake finish
front jacks are on side along with built in fan controller and sata HD plugin
Front pannel
Theres a 12" blue cathode in the front door. I'm going to sleeve the actual cold cathode lite with hot pink vinyl film.
This case is TOP QUALITY and a real beauty. It looks quite nice sitting next to the Silver Lian-Li V2000.
WC'ing setup
Danger Den TDX CPU block
MCP355 pump with Alphacool Laing DDC Clear Acrylic Top with 5mm hot pink led.
PrimoChill Typhoon Acrylic-Single 5 1/4 Clear reservoir with 5mm hot pink led.
CoolRad 12T120mm Radiator. painted silver
Masterkleer Tubing 7/16" ID 5/8" OD
Front pannel
WC'ing setup
