32gb just fine for now and for thr next few years. 64GB is overkill. 128GB is burning money for giggles.128 GB of RAM is nice if it's ever needed
There's nothing wring with AS5. You'd be chasing after 1-3C at most with a different paste. I like MX-4 (2019 edition) and it's ~1C better than AS5.What do you recommend for paste?
I'll bite... why? Feels like we missed critical context from this statement...Better get a splitter for my fans.
I wont ask who you're agreeing with as nobody mentioned BT previously, lol.
Agreed, but I think he's looking at the X570 WiFi model.On a serious note, in order to get BT, you actually need Wi-Fi which you mentioned you didn't previously. So if you require BT, then your board needs to have Wi-Fi (or buy a Wi-Fi card and install it) as that's all on the same AIC.
You can also look at B550 boards, or X570S. They are both newer than X570 and offer some updated features. B550 has some PCIe lane limitations, but so long as you're not trying to rock more than 2 M.2 modules and 4/5 SATA drives, you'll be fine.
EDIT: Im also not sure that X570 natively supports 5000 series out of the box. So unless you have a 3000 series or the board you choose has a bios flashback feature (flash without CPU).....or the board was produced late enough to have a BIOS that works with 5000 series.
