Guys i found this one this is good ? http://www.pcgarage.ro/coolere/cooler-master/hyper-103/
The Coolermaster 212 evo is probably the best value when both cost and performance are considered of any air cooler on the market. Don't cut corners on your cooling. It is very critical to good overclocking results.
I think he's hoping to get 4.5 ghz which is certainly attainable on air with a decent motherboard - which is his other deficiency at this point.
Liquid cooling seems to go hand and hand with FX processors.
Yes, but that may only be true with custom water loops. Even the best AIO water cooling units give temps that are only 2-4c lower than the best air coolers, at least in the 125-150W range. And then there are issues with water cooling that may cancel that small dif out such as noise levels and pump failure. Check this out: http://www.frostytech.com/articleview.cfm?articleid=2752&page=4
IMO, Frostytech is the best source for getting accurate information on cooler comparisons and they have a pretty big data base. Their testing is done synthetically so a lot of the test variables are eliminated. Their numbers match very closely to what I'm seeing with my Noctua D14 vs. the several AIO water cooling units I have tested lately that are on their list. Since my Nepton 240L pump started emitting a very noticeable high pitched squeal after less than two weeks of use I have (temporarily, at least) gone back to my Noctua and find I really like it. So much quieter.
I think there is this misconception out their that water cooling will necessarily be better than air cooling but the data just doesn't bear that out.
My custom liquid loop doesn't seem to be on the frosty site.
Did you expect it to be? Let's compare apples with apples and oranges with oranges. Custom loops are not on the OP's radar as yet.
Would never suggest air cooling or AIO for an overclocker. At least I try not too. But alas, people's budgets may not be as large as mine to run more than just one radiator.......
Why not? Respectable overclocking can still be done with either good retail air coolers or good retail water cooler AIO kits. Of course, you can't push the OC as far as you could with a custom loop. Nobody is suggesting you can here in this thread.
Gladly put my custom liquid loops against air cooling with the same processor any day. And my custom water loop will absolutely annihilate air coolers.
Undoubtedly. But were we talking about custom loops in the thread or are you just wanting to brag?
My little box? Not sure what you refer to. I just try not to jump out of the box that seems to be defined by the context of the thread and what the OP is giving us to work with. I have nothing against custom water loops. I recognize they offer superior cooling. If they weren't so expensive I probably would have one myself and the OP might go for one as well.
S_B said:Holes wore in at mounting holes.
