- Jun 23, 2014
- Thread Starter
- #41
...knocked backwards at the power it really takes to run AC4BF. Not for weak systems at all it seems.
http://www.hardwarepal.com/assassins-creed-4-black-flag-benchmark-cpu-gpu/2/
Recommended configuration Operating System: Windows Vista SP2 or Windows 7 SP1 or Windows 8 (both 32/64bit versions) Processor: Intel Core i5 2400S @ 2.5 GHz or AMD Phenom II x4 940 @ 3.0 GHz or better RAM: 4GB or more Video card: Nvidia GeForce GTX 470 or AMD Radeon HD 5850 (1024MB VRAM with Shader Model 5.0) or better
Read more: Assassin’s Creed 4 : Black Flag Benchmark – CPU and GPU http://www.hardwarepal.com/assassins-creed-4-black-flag-benchmark-cpu-gpu/
You can 'read more' at that link there from the beginning and see just what sort of actual performance can be expected from a "big rig" running AC4BF.
Surely g00gling Nvidia Gt 630 vs nvidia GeForce GTX 470 will show a huge difference in the performance of those two video cards. Huge difference in performance. Now stop and think what even they will do compared to Benchmark Rigs and Components at the link just below:
http://www.hardwarepal.com/assassins-creed-4-black-flag-benchmark-cpu-gpu/3/
Now flip on over to page #5 of that article and see the 1920x1080 GPU Benches.
http://www.hardwarepal.com/assassins-creed-4-black-flag-benchmark-cpu-gpu/5/
I had no idea of the power requirements for playing AC4BF. They are not meager requirements by any means. Let me make that power just to play or power to play "really" well. They are very far apart it seems and this review is only about 6 mos old.
Sure getting a few more beats at the cpu level would be good, but that seems far from being what is really wrong with the OP's ability to 'really' play the game. Play the game without so much frame drop.
Awestruck RGone...ster.
EDIT:
I did some more g00gling and found website GameDebate com and filled out their questionaire about the system in question and asked it to tell me how the parts and pieces stacked up in the game.
Here is the link to this particular systems stack-up.
http://www.game-debate.com/games/in...Edition&ram=4&checkSubmit=#systemRequirements
Since I don't trust that link to work for everyone, I captured the screen of results as I veiwed them myself. The Projected FPS are not visisble because I am NOT a premium member. But look at how far the GPU lags behiind in even reaching the 100% playable mark. Even the FX-4100 did not quite reach the 100% mark.
See the image for my edit about the RAM which is not even running in dual channel according to CPUz.
Now after becoming more acclimated to AC4BF, I just don't see how focusing much on the cpu is going to make AC4BF very playable.
END EDIT.
EDIT #2:
When going back over this post I noticed something else as well. Something I cannot change in the spec system since am not a member. Look at the resolution that the results are given for. > 1280 x 1024. So if the OP is using what maybe todays normal monitor resolution of 1920 x 1080, then that showing of results would show his system lacking even more.
END EDIT #2.
Thank you for the info sir so i must change my procesor and my video card + new coolers?
