Kevin it's your rig so you need to figure out what OC is best. You can leave it at 4.5 and fine tune it, 4.5 is a pretty darn good OC. If you want to try and see how far it will go, then when working on the Oc using the multiplier you need to watch and/ or change 3 things, the mutiplier, Cpu V and Temps. If you're 2 hours prime blend stable at 4.5 then just raise the multiplier .5 run 20 minutes of Prime blend watch the temps, below 70 C on the Cpu and 62 C on the package, rinse and repeat. Once it fails 20 minutes of prime, drop the mutiplier back down .5 and try and pass 2 hours of Prime Blend. If at any point you fail prime during that 2 hours and the temps are still below the suggested max, raise the Cpu V .00625 or hit the + key once, and re run prime. Rinse and repeat until you pass 2 hours or you hit the suggested temps. You may also want to go to the Cpu Nb voltage and raise it to 1.20-1.25 V as RGone suggested.Ok il switch the dram down to 1600 as suggested, do I have any options to fine tune at the 4.5 I'm at now or should I consider pushing a little more, Where am I likley to find the best performance but without causing it to degrade too fast?
RGone the pc is off with me at the moment but as soon as I'm on it in the morning il set it to 1.18, sorry I don't know how to quote and answer.
Any time you Oc you run the risk of degradation or failure. That said I'm working on my 3rd year of a 4.0Ghz daily OC on Air of my AMD 955be, 2nd year of my I5 2500k 4.5 Oc on Air and a little over a year at 4.7 on my Fx 8350. All 3 chips have been pushed pretty hard for benching and have seen voltage a lot higher then I will even mention. I have not seen any sign of degradation on any of them, nor have I "knock on wood" killed a Cpu yet by overclocking it.Where am I likely to find the best performance but without causing it to degrade too fast?
I use speed fan when doing blend tests so I can see if any of the cores fail
