Sometimes you'll run into a problem with certain sets of RAM acting up/crazy but there is a possible fix, provided the sticks are known to actually be good in the first place.
The fix I discovered is if you have a set that acts like it's not wanting to work with the board, get the system to boot and go into the BIOS. Then go into your RAM settings and you'll see at the very top the option to "Load 4GB settings" or something like that.
Select this, use a lower RAM divider such as 1600 and reboot the system, then go back into the BIOS and try your tweaks. For some reason the board with certain sets doesn't seem the like them at first but will do better by loading this default, then tweaking the sticks as you want.
Note that this has worked with my CHV-Z, I've yet to have any real issues with my Sabo and RAM but doesn't hurt to try it if nothing else seems to be working.
In my case this allowed me to go higher with better stability so that could help with stability issues encountered.
EDIT: Just fired up my Sabo and noted it doesn't have the option to load 4GB settings so that's not applicable to your Sabo either.
I'm suprised it wasn't included in it's BIOS like it is with the CHV-Z.
