- Jan 10, 2012
that is a steller processor and board combo!!!
M5A99 EVO = SCRATCH that and get a Sabertooth 990FX R2.0 and you will be oh so much better off and happy in the long run.
As you said you got the silicon lottery winner on the cpu you have and thru dumb luck picked a good mobo. Now do not shoot yourself in the foot before starting the race with FX and go for a board that has NO chance of looking like a lottery winner with the FX-6300. Get Sabertooth 990FX R2.0 not some mid-level mobo that is going to limit you from the get go in overclocking.
RGone...ster.
Yup!
It is your parts and somebody, maybe it was you earlier, said their cpu did not like the 20x multiplier. That is why overclocking is such trial and error and what works is really what works at your end.
RGone...ster.
Not much risk. I have another rig with a 910 in it. A 965 would make for a nice upgrade. I had this 965 in it before. I can tell the difference with the 910 back in it. Then I can try the 910 with the locked multi just to see.
Nice catch!Hey poco, great to see the phII scaling past 4.2ghz.
I have noticed something though which could change things either for the better or worse.
I've noticed that you are running your memory in single channel mode,
You will be experiencing reduced bandwidth if you were to do some aida64 memory bandwidth tests. More importantly though the single channel memory mode could be the reason why your cpu clock is so high along with your imc, which is stable at the timings and speed you are running it at, although that could be due to the ram modules you are using too.
It maybe that running in dual channel mode will reduce your stability of your cpu speed, it may help it. But if you can would you be able to bench your aida 64 read, write, copy results between single mode, and dual channel mode.
