- Apr 20, 2004
- JAX, Mississauna
I never set anything on the memory. That is just how the BIOS set it. I may be wrong, but isn't duel channel used with 4 sticks of memory? I only have 2. Could I have then installed wrong? Both on the same channel? I put them in the first 2 slots next to the CPU. One blue and one black slot. I know when I put it together I wasn't sure on that.
Single vs Dual channel on that AMD board should be determined by HOW you have placed the memory in the slots for the memory. I bet you have 2 sticks sitting in ram slots side by side and that is normally Single channel.
In the mobo manual it shows which slots are to be used for Single and Dual channel "before" you get to 4 sticks. For most maybe not all AMD boards it is begin with slot closer to cpu for one stick of ram and then skipping one slot and putting the second stick in, sets Dual channel ram mode. Check your manual for accuracy of that statement.
RGone...ster.
