I think you conclusions about fan directions and placement are valid.
Shady, if you at all handy with tools you could always cut a hole in the top and mount a 120mm fan or two up there. I don't know how much it will help, but it should make some difference. That's if you want to basically ruin the case for resale.
Well you could open the case door and see how it helps. As far as dust goes, if you are diligent about keeping it clean you should be fine. You could even rig it up with the case door open and a house fan blowing in.
Is it the fan itself that is vibrating, you could always try to lubricate it, it does help.
I see, well it looks like a new heatsink and case are my first priorities then. I make around $60 a month at the moment, so I should have enough saved up in 6-12 months to get a fulltower and new heatsink
Self pity aside, thanks for the help everyone! I'm glad I learned that airflow/cooling is going to be my first priority here, before I just went straight to attempting to overclock.
One last thing, I've heard mentions of turning off 2 cores on the 1090t, perhaps I could try this, and overclock the remaining 4? I'm not entirely sure if this would hurt livestreaming and video rendering times, or improve them. I believe as far as gaming concerns 4 extremely fast cores are infinitely better than 6 decent cores, since 99% of games only use 4 cores. Or is this an outdated belief?
car oil should work fine just a drop though.
Much better temps, though you still don't have a lot of headroom for overclocking. What I would do is turn off all the power saving features in the BIOS and then start using the multiplier .5 at a time to overclock it. Then test with prime, watch that the socket temps don't go above 60's as well as the core temps. You may be able to run them higher, I'm not well versed with the 6 core processors.
Sometimes we need to make due with what we have, canola oil may work, I don't see any harm in trying it.
At 55c on the cores you are around the area that you may find instability on a Denub I'm not sure about the Thubans. I would leave it where it is and see if you can pass 2 hours prime keeping a close eye on the temps. Some of the tests stress the cpu a little harder so watching the temps is key. What are your ambient temps? I'm just wondering why your gpu temps is at 51c. Not that it's a concern, it just seems a bit high for an idle temp.
