220s are unlockable? I didn't know that.
This >> AMD Athlon II X2 220 << with a REGOR core is only a 2 core cpu. That is why Linux only finds two cores.
There are four (4) lines of print on the lid of most any AMD K10 processor. The third line can be used to determine the "core" the cpu is made on/from.
Identifying underlying base core is easy from the markings on the CPU.
The first line of markings contains family name. Normally larger letters than the next three lines of text.
The second line has OEM part number.
The third line contains stepping code: XXXXX (xx) XXXXXXX/X
The fourth line is of no consequence in this exercise.
AC - Deneb >> Third line XXXXX (AC) Denab core.
AD - Propus >> Third line XXXXX (AD) Propus core.
AE - Regor >> Third line XXXXX (AE) Regor core. 2 cores only. No 4 cores hidden or otherwise.
CB - Thuban >> Third line XXXXX (CB) Thuban core.
So you can pull the cpu cooler and look at the two characters described above and know that REGOR core will not unlock.
If one enables ACC on a cpu that has NO cores to unlock, nothing happens except that the ACC enable has disabled the ability for most software to read the CPU CORE TEMPS.
