- Dec 13, 2013
- Great White North, MN
I am VERY new to overclocking. I have always bought off the shelf PC's and upgraded when needed. I recently did my first build. It is not a high end build. Middle of the road. I do a little gaming, but games like NFS Hot Pursuit so my needs are not that great.
Anyway I have been playing around with overclocking. I have had good luck doing the CPU, (AMD Phanom II 965). I have that stable at 3.8ghz running Prime95 for a while. The last couple of days I have been messing with the graphics card through AMD overdrive. (The CPU I did through BIOIS) It is a Saphire HD 7770. Stock GPU clock is 1000mhz. I bumped it up to 1150 and boosted the memory up 150hz and the voltage up 5%. It is stable and I picked up 400 points testing on 3DMark. I tried for 1200 but get a BSOD code 116 when the test starts. The thing I do not know is on that test I had the memory clock the same as the GPU clock. Should the memory clock be higher than the GPU? Is that maybe why it crashed? I am doing this for fun. Stock it will play every game I play at max settings anyway. I do more HD video editing than games playing. It works great for that.
Any insight would be appreciated.
