- Jan 24, 2006
- Colorado
Hey all, the board in the rig in my sig is having an issue.
No matter what, everytiem I restart, shutdown, etc. I have to restart the dang thing like 6 times before it will boot correctly.
The memory has tested fine, and all the other components are exactly the same way before the upgrade. Basically, what happens:
POST happens, no problem.
Then SATA detection, no problem.
Then..nothing.
The screen is blank, and the monitor is still recieving a signal from the video card. It's getting very annoying, and the only thing Asus Support can say is RMA the board. I really, cannot go without a computer for more than a Day.
1. Foldign
2. School
3. Work
Anyone else ever expeience problems with this board, or with a similar situation? Hopefully someone is on that can help. Thanks!
Then..nothing.
1. Foldign
2. School
3. Work
