Hello all. I just got my P5N-E SLI a few days ago, with a Core 2 Duo E6400 and 2gb Corsair DDR2-800 with an nVidia 8800 GTS 320. I've been having some pretty big problems with any overclocking attempts.
First off, the only way I've found to change the FSB speed is under the "Jumper-Free Configuration" menu, turning "AI Tuning" to manual, and then going to "FSB & Memory Config" menu.
If I change the FSB-Memory Clock Mode to Unlinked, my system can't boot into windows, even if I leave the clock speeds untouched. If I link them, and change the ratio at all, or even change the FSB clock, it only lets me change it from 1066, instead of the 4xx MHz you guys are showing...
In case you hadn't noticed, I'm a COMPLETE novice when it comes to overclocking, and I've been reading about different boards and CPUs for a couple months and wanted to play with it, but I can't even get that far yet it seems.
If I change the clock (Labeled "FSB (QDR), MHz") to anything other than 1066 MHz, it will not boot into windows. If I enable the AI Overclocking, and then tell it to overclock by 5%, it will not only fail to boot, but will not even POST until I manually clear the CMOS.
Any ideas would be greatly appreciated! Thanks for humoring my ignorance as well! I'm always thrilled to learn something new and this seems like the place to do so.
Thanks again!
