I dont use an offsst. I set the voltage manually. If i have any vdroop, i then compensate with LLC so the voltage i set in bios = load voltage in windows. If i keep windows power plan to balanced, it still drops voltage.
Running an ASUS board, goes past the first ASUS logo but when it goes to the 2nd (Windows logo) replaced with ASUS logo, PC sometimes hangs...doesn't actually load.
Aside from a usb port triggering this, and whatever is plugged into it, is there anything else I should troubleshoot?
Does anyone know what setting may cause the usb port and what is plugged into it cause this?
That's all I've been able to find during my research.
Thanks.
For a USB drive causing this, I would unplug it and plug it back in and make sure it's not loose-fitting! For other issues, I dunno, but more likely to occur with laptops... I suspect the 2.5 inch'er spinners in many of them!
Needing CPU LLC=Then in my experience, it randomly fails to boot at all, it usually randomly fails to POST!
Pepi93, is the overclock itself stable under stress testing (OCCT, Prime95, etc.) after you have booted into Windows? If so, the issue would seem to be that you are using technologies that supplement the vcore under load to provide stability but are not operative at other times, such as at boot. So it would seem to me you need to do something to keep the load voltage where it is while giving a modest boost to the voltage at other times, such as during boot.
If I'm over clocked and I enable c states, it would bsod on logo. Maybe some kind of power saving feature gets stuck? Have you tried disabling any of those? I don't know which ones new CPUs have..
Try reducing the CPU multiplier by 1x and see if the hanging goes away. That should tell you something.
Time to set everything to default and see what happens.
