So, been sitting on this ol' AMD Phenom II x4 940BE AM2+ based machine with the MA770-UD3 mobo for quiet awhile. Got four modules of 2GB RAM at 800MHz in all the DIMMs from G.Skill, I forget what I sat their timings at as the time of typing this, however. A TX650W gold from Corsair sitting in there feeding power to the various devices, accompanied by two 1TB and one 640GB Western Digital Black in the platter based HDD section. Also some generic Lite-On optical driver reader/burner with general DL support. Now the kicker, a severely bottle-necked GTX970 from MSi sitting in there having recently replaced an oddly acting GTX570 from eVGA. (Figured I would just move it over eventually to a new build, though I did gain small performance boosts in some games with it. Obviously ones not as reliant on the CPU.)
ANYWAY, digression.
Been poking about, and Intel seems to be getting those IPC counts up there for their clockings, and I haven't followed Intel for a long time. I don't really favour some of their political or social choices as of late, but as far as I am concerned I am more interested in that power.
A friend of mine mentioned about their upcoming Skylake, and it seems to be only info on them is the smaller manufacturer process. Which would be nice, but the current AMD I am on is already a 32 so going to a 22 on LGA1150 would already be an improvement in that term.
Again, digression.
My main plight is in terms of what seems to be viable mobos for someone more likely to use a single GPU, possibly a second non-same GPU just to offload onto a second monitor while main gets the full brunt of the main GPU. (Though with the included Intel GPU arch on the CPU, I could probably just offload the second screen with that for general web browsing/video watching.) Looking through Newegg shows a lot of these Z97 boards with rather poor reviews, which is somewhat disheartening.
I mainly want something with at least 6 SATA ports, PCI-e 3.0 based slot for the GPU to move to, and has a decent environment for OC'ing but isn't too expensive. DDR3 class based, as DDR4 is way too much for the current offerings. Any help would be beneficial, even build ideas. I mainly just need to replace the mobo/RAM/CPU, possibly HS as I think the old one I have now might not work with the LGA1150 slot mount system. I still have a tube of AS5 laying around somewhere, though.
So far I was looking at:
HS: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Higher-CPU Choice: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
Lower-CPU Choice: http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231719 (With plan to get another module later)
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128707 Not much a fan on the price, have never really paid more than 120 for Mobos before, but this seems to have the better ratio of high eggs to low ones and meets my requests on the slots.
PS Edit:
Would like to keep it between $400-$600.
ANYWAY, digression.
Again, digression.
PS Edit:
