- Nov 10, 2012
- Ankeny Iowa
Just ordered it today
Now to get the WC parts coming
nope it was a because I can thing lol. I made a trade with a guy on [H] for the rez, he also had that monsta 240. Which 240mm rad is all that will fit in the front without modding opti bays, so I made another deal with him for the monsta. Before temps were 34 cpu 30 each gpu idle, under load with prime95 45min run hottest core was 61 heaving gaming session gpus never went above 45. Right now (no stress's ran yet) idle temps are 30cpu 26 both gpu's gonna fire up prime in a bit and do a 45min run and see what goes. But we all no more rads dont always mean lower temps I just did it for ****s and giggles and I've been wanting to clean up the tubing as I had it running everywhere before due to dual loops.
ok prime95 for n hour cpu hottest core 56 so looking like a 4c drop overall for temps with the 3rd rad. GPU's seem to of made out better lol ran the gpu test from gpu-z for 45mins gpu1 37 gpu2 39 very nice indeed lol.
I should mention front 240mm monsta rad had fans in push on 12v havent put them on a controller yet. Using 140mm spectre pro's in the front of the case and took 2 old 120mm coolermaster sickle flows and cut the fan out making fan spacers with them. The rest of the fans for the 280 and 420 as well as the rear exhaust are being controlled PWM thru the cpu header on the mobo. I can actually see them ramp up due to the leds on them when I put the system under load. Now to see about getting another PWM controller like the one that comes with the case for the other fans lol. Its only 2 additional fans but Phanteks makes it clear no more than 11 fans on their included controller.
Beware, with all this space your eyes will get bigger than your budget. You will love it.Just ordered it today
Nice! Glad your temps dropped. CPU's are so emo. I am sure once the right fans are put in place your temps will improve a bit in the loop. Nice drop on the GPUs though. 5c-8c Delta on load? Tells us! lol
Also if you need something affordable for PWM, this will work as well if you can't get more than 1 Phantek PWM hub.
Or the other way around. With all this space his budget will get bigger. LOL At least that's what is happening with me. lawl
Too late
Now with all this space how many monsta Rads can I fit?
Maybe 2 360's? one top one bottom push/pull config
Maybe WC the twin 7770's too
I am thinking this for the build:
A monsta rad 480mm push/pull on bottom
A photon rez/pump combo
A XSPC Raystorm cpu block
uv blue tubing
phanteks blue led pwm fans
Received my new case and all I can say is
This thing is a beast in size
Can't wait to start a build log on this sucker
