# dmidecode 2.11
SMBIOS 2.5 present.
67 structures occupying 2442 bytes.
Table at 0x0009F400.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: American Megatrends Inc.
Version: 2102
Release Date: 06/17/2010
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 1024 kB
Characteristics:
ISA is supported
PCI is supported
PNP is supported
APM is supported
BIOS is upgradeable
BIOS shadowing is allowed
ESCD support is available
Boot from CD is supported
Selectable boot is supported
BIOS ROM is socketed
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 8.15
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: System manufacturer
Product Name: System Product Name
Version: System Version
Serial Number: System Serial Number
UUID: 0059001E-8C00-003D-1ECB-BCAEC5B31F76
Wake-up Type: Power Switch
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Manufacturer: ASUSTeK Computer INC.
Product Name: M4A79XTD EVO
Version: Rev X.0X
Serial Number: MT700CK19501272
Asset Tag: To Be Filled By O.E.M.
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: To Be Filled By O.E.M.
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 21 bytes
Chassis Information
Manufacturer: Chassis Manufacture
Type: Desktop
Lock: Not Present
Version: Chassis Version
Serial Number: Chassis Serial Number
Asset Tag: Asset-1234567890
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000001
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
Handle 0x0004, DMI type 4, 40 bytes
Processor Information
Socket Designation: AM3
Type: Central Processor
Family: Phenom II
Manufacturer: AMD
ID: 43 0F 10 00 FF FB 8B 17
Signature: Family 16, Model 4, Stepping 3
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
HTT (Multi-threading)
Version: AMD Phenom(tm) II X4 965 Processor
Voltage: 1.5 V
External Clock: 200 MHz
Max Speed: 4000 MHz
Current Speed: 4000 MHz
Status: Populated, Enabled
Upgrade: Other
L1 Cache Handle: 0x0005
L2 Cache Handle: 0x0006
L3 Cache Handle: 0x0007
Serial Number: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 4
Core Enabled: 4
Characteristics:
64-bit capable
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1-Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Varies With Memory Address
Installed Size: 512 kB
Maximum Size: 512 kB
Supported SRAM Types:
Pipeline Burst
Installed SRAM Type: Pipeline Burst
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Data
Associativity: 4-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2-Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 2048 kB
Maximum Size: 2048 kB
Pipeline Burst
Speed: Unknown
System Type: Unified
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3-Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 6144 kB
Maximum Size: 6144 kB
Pipeline Burst
Speed: Unknown
Handle 0x0008, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: PS/2 Mouse
Internal Connector Type: None
External Reference Designator: PS2Mouse
External Connector Type: PS/2
Port Type: Mouse Port
Handle 0x0009, DMI type 8, 9 bytes
Internal Reference Designator: PS/2 KeyBoard
External Reference Designator: Keyboard
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
Internal Reference Designator: USB78
External Reference Designator: USB78
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: SPDIF_O
External Reference Designator: SPDIF_O1
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: USB56
External Reference Designator: USB56
Port Type: USB
Handle 0x000D, DMI type 8, 9 bytes
Internal Reference Designator: USB34
External Reference Designator: USB34
Port Type: USB
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: IE1394_1
External Reference Designator: 1394
External Connector Type: IEEE 1394
Port Type: Firewire (IEEE P1394)
Handle 0x000F, DMI type 8, 9 bytes
Internal Reference Designator: ESATA
External Reference Designator: ESATA
External Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x0010, DMI type 8, 9 bytes
Internal Reference Designator: LAN
External Reference Designator: LAN
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: USB12
External Reference Designator: USB12
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
Internal Reference Designator: Line In
External Reference Designator: Line In
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: Line Out
External Reference Designator: Line Out
Handle 0x0014, DMI type 8, 9 bytes
Internal Reference Designator: Mic In
External Reference Designator: Mic In
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: Center Out
External Reference Designator: Center Out
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: Surround Out
External Reference Designator: Surround Out
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: Side Surround
External Reference Designator: Side Surround Out
Handle 0x0018, DMI type 8, 9 bytes
Internal Reference Designator: CPU_FAN
Internal Connector Type: Other
External Reference Designator: Not Specified
External Connector Type: None
Port Type: Other
Handle 0x0019, DMI type 8, 9 bytes
Internal Reference Designator: PWR_FAN
Port Type: Other
Handle 0x001A, DMI type 8, 9 bytes
Internal Reference Designator: CHA_FAN1
Port Type: Other
Handle 0x001B, DMI type 8, 9 bytes
Internal Reference Designator: CHA_FAN2
Port Type: Other
Handle 0x001C, DMI type 8, 9 bytes
Internal Reference Designator: COM1
Internal Connector Type: 9 Pin Dual Inline (pin 10 cut)
Port Type: Other
Handle 0x001D, DMI type 8, 9 bytes
Internal Reference Designator: PRI_IDE
Internal Connector Type: On Board IDE
Port Type: Other
Handle 0x001E, DMI type 8, 9 bytes
Internal Reference Designator: AAFP
Internal Connector Type: Mini Jack (headphones)
Handle 0x001F, DMI type 8, 9 bytes
Internal Reference Designator: SPDIF_OUT
Handle 0x0020, DMI type 8, 9 bytes
Internal Reference Designator: CD
Internal Connector Type: On Board Sound Input From CD-ROM
Handle 0x0021, DMI type 8, 9 bytes
Internal Reference Designator: IE1394_2
Internal Connector Type: IEEE 1394
Handle 0x0022, DMI type 8, 9 bytes
Internal Reference Designator: USB910
Internal Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x0023, DMI type 8, 9 bytes
Internal Reference Designator: USB1112
Port Type: USB
Handle 0x0024, DMI type 8, 9 bytes
Internal Reference Designator: SATA1
Internal Connector Type: SAS/SATA Plug Receptacle
Port Type: SATA
Handle 0x0025, DMI type 8, 9 bytes
Internal Reference Designator: SATA2
Port Type: SATA
Handle 0x0026, DMI type 8, 9 bytes
Internal Reference Designator: SATA3
Port Type: SATA
Handle 0x0027, DMI type 8, 9 bytes
Internal Reference Designator: SATA4
Port Type: SATA
Handle 0x0028, DMI type 8, 9 bytes
Internal Reference Designator: SATA5
Port Type: SATA
Handle 0x0029, DMI type 8, 9 bytes
Internal Reference Designator: SATA6
Port Type: SATA
Handle 0x002A, DMI type 8, 9 bytes
Internal Reference Designator: SATA_E1
Port Type: SATA
Handle 0x002B, DMI type 8, 9 bytes
Internal Reference Designator: PANEL
Port Type: Other
Handle 0x002C, DMI type 9, 13 bytes
System Slot Information
Designation: PCIEX16_1
Type: x16 PCI Express
Current Usage: Available
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
PME signal is supported
Handle 0x002D, DMI type 9, 13 bytes
Designation: PCIEX16_2
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x002E, DMI type 9, 13 bytes
Designation: PCIEX1_1
Type: x1 PCI Express
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x002F, DMI type 9, 13 bytes
Designation: PCIEX1_2
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0030, DMI type 9, 13 bytes
Designation: PCI1
Type: 32-bit PCI
Current Usage: In Use
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0031, DMI type 9, 13 bytes
Designation: PCI2
Type: 32-bit PCI
Length: Short
Characteristics:
3.3 V is provided
Opening is shared
Handle 0x0032, DMI type 10, 6 bytes
On Board Device Information
Type: Video
Status: Enabled
Description: To Be Filled By O.E.M.
Handle 0x0033, DMI type 11, 5 bytes
OEM Strings
String 1: BCAEC5B31F76
String 2: To Be Filled By O.E.M.
String 3: To Be Filled By O.E.M.
String 4: To Be Filled By O.E.M.
Handle 0x0034, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 1
en|US|iso8859-1
Currently Installed Language: en|US|iso8859-1
Handle 0x0035, DMI type 15, 35 bytes
System Event Log
Area Length: 4 bytes
Header Start Offset: 0x0000
Header Length: 2 bytes
Data Start Offset: 0x0002
Access Method: Indexed I/O, one 16-bit index port, one 8-bit data port
Access Address: Index 0x046A, Data 0x046C
Status: Invalid, Not Full
Change Token: 0x00000000
Header Format: No Header
Supported Log Type Descriptors: 6
Descriptor 1: End of log
Data Format 1: OEM-specific
Descriptor 2: End of log
Data Format 2: OEM-specific
Descriptor 3: End of log
Data Format 3: OEM-specific
Descriptor 4: End of log
Data Format 4: OEM-specific
Descriptor 5: End of log
Data Format 5: OEM-specific
Descriptor 6: End of log
Data Format 6: OEM-specific
Handle 0x0036, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 16 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0037, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x0032FFFFFFF
Range Size: 13056 MB
Physical Array Handle: 0x0036
Partition Width: 1
Handle 0x0038, DMI type 17, 27 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM0
Bank Locator: BANK0
Type: Other
Type Detail: Synchronous
Speed: 1600 MHz
Manufacturer: Manufacturer00
Serial Number: SerNum00
Asset Tag: AssetTagNum0
Part Number: ModulePartNumber00
Handle 0x0039, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x0038
Memory Array Mapped Address Handle: 0x0037
Partition Row Position: 1
Handle 0x003A, DMI type 17, 27 bytes
Memory Device
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: BANK1
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: Manufacturer01
Serial Number: SerNum01
Asset Tag: AssetTagNum1
Part Number: ModulePartNumber01
Handle 0x003B, DMI type 126, 19 bytes
Inactive
Handle 0x003C, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM2
Bank Locator: BANK2
Type: Other
Speed: 1600 MHz
Manufacturer: Manufacturer02
Serial Number: SerNum02
Asset Tag: AssetTagNum2
Part Number: ModulePartNumber02
Handle 0x003D, DMI type 20, 19 bytes
Starting Address: 0x00100000000
Ending Address: 0x001FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x003C
Handle 0x003E, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM3
Bank Locator: BANK3
Type: Other
Speed: 1600 MHz
Manufacturer: Manufacturer03
Serial Number: SerNum03
Asset Tag: AssetTagNum3
Part Number: ModulePartNumber03
Handle 0x003F, DMI type 20, 19 bytes
Starting Address: 0x00200000000
Ending Address: 0x002FFFFFFFF
Range Size: 4 GB
Physical Device Handle: 0x003E
Handle 0x0040, DMI type 32, 20 bytes
System Boot Information
Status: No errors detected
Handle 0x0041, DMI type 139, 94 bytes
OEM-specific Type
Header and Data:
8B 5E 41 00 00 1E 8C 00 00 3D 1E CB 04 04 32 55
F8 00 A2 02 A1 00 40 63 43 10 84 83 03 DF 40 80
00 20 00 73 3C 10 08 00 60 0F 06 11 15 04 20 00
3C 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 CB 1E 3D FF FF 8C 1E 00 04 00 00 23
33 00 00 00 00 00 00 00 00 00 00 00 00 01
Strings:
V1394GUID
Handle 0x0042, DMI type 127, 4 bytes
End Of Table
