- Jan 12, 2012
It all depends on what the person considers "extreme" overclocking."You do not need extra cooling when the FET is soldered to a large ground plane / cooling surface and spread the heat across the motherboard. If you're gonna overclock it extremely you may want to get an extra cooler though".
You should post a pic of hwmonitor under prime95 "blend torture test" for 20 minutes so we can see what your temps are. When you say 55c on the cpu is that the socket temp or the cores?
