heh geeszs nothing but problems ?
If you're running Windows XP, the "Safely Remove Hardware" icon is there to stay, unless you rewrite the SATA/IDE(?) bus drivers for it not to be this way or do something similarly outrageous.
But there is a simple alternative, as you can hide the icon by doing this:
* right click on the task bar, select Properties. (or go to "Taskbar and Start Menu" in the Control Panel)
* click Customize
* Find the icon and select "Always Hide".
Voila. That's what I did.
Since nForce4 chipsets support hot-pluggable HDDs, the HDDs are recognized by Windows as removable devices. And as removable devices, they have the icon.
But if it's Win2K or an otherwise non-XP OS, then you may have to look for an alternate solution. I don't know of any off hand.
