- Jul 24, 2002
- Seattle, WA
Ah - that makes more sense. I thought you were moving the pagefile TO the second drive, not from.
That would confuse me. Why shouldn't the pagefile be on the system drive? If you put it on the other drive, now you have more things that can go wrong, not less. I really don't think that's it - I would look to the Intel RST and chipset drivers first. *shrug*
And my logic is that if there are disk, controller, or file system issues on the primary hard drive, you're going to have more problems than just your pagefile.My logic for moving the page file to a different drive lies in assuming that there may be issues with either the disk, controller, or file system on the primary hard drive
Yes and no....
I would next advise the OP to move the page file back onto the primary drive, after another few days or so of no BSOD's, and see whether the BSOD's return. This way, we'll know whether the driver update corrected the issue or not.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: d1
BCP1: FFFFF8A0046E7298
BCP2: 0000000000000002
BCP3: 0000000000000000
BCP4: FFFFF8800105EFA9
OS Version: 6_1_7600
Service Pack: 0_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\041511-34866-01.dmp
C:\Users\Mihail\AppData\Local\Temp\WER-61994-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Unable to load image \SystemRoot\system32\DRIVERS\stflt.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for stflt.sys
*** ERROR: Module load completed but symbols could not be loaded for stflt.sys
Probably caused by : stflt.sys ( stflt+1ed9 )
Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\Dan\AppData\Local\Temp\041511-34866-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Machine Name:
Kernel base = 0xfffff800`02e0f000 PsLoadedModuleList = 0xfffff800`0304ce50
Debug session time: Fri Apr 15 13:40:08.747 2011 (GMT+1)
System Uptime: 0 days 0:30:10.058
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck D1, {fffff8a0046e7298, 2, 0, fffff8800105efa9}
Followup: MachineOwner
2: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: fffff8a0046e7298, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff8800105efa9, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff800030b70e0
fffff8a0046e7298
CURRENT_IRQL: 2
FAULTING_IP:
fltmgr!GetContextFromStreamList+99
fffff880`0105efa9 488b4820 mov rcx,qword ptr [rax+20h]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: System
TRAP_FRAME: fffff88002f8c330 -- (.trap 0xfffff88002f8c330)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=fffff8a0046e7278 rbx=0000000000000000 rcx=fffffa800cb1ec30
rdx=fffffa800d53e070 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8800105efa9 rsp=fffff88002f8c4c0 rbp=fffffa8009c743c8
r8=fffffa800d970010 r9=fffff88002f8c5d8 r10=fffffa800cb1ec38
r11=0000000000000011 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na po nc
fltmgr!GetContextFromStreamList+0x99:
fffff880`0105efa9 488b4820 mov rcx,qword ptr [rax+20h] ds:c000:fffff8a0`046e7298=fffffa800d8bb220
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002e80469 to fffff80002e80f00
STACK_TEXT:
fffff880`02f8c1e8 fffff800`02e80469 : 00000000`0000000a fffff8a0`046e7298 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02f8c1f0 fffff800`02e7f0e0 : 00000000`00002710 00000000`00000000 fffff800`02e8dbac 00000000`00000011 : nt!KiBugCheckDispatch+0x69
fffff880`02f8c330 fffff880`0105efa9 : 00000000`00000000 00000000`00000000 fffff880`02f8c570 fffff880`0105e32e : nt!KiPageFault+0x260
fffff880`02f8c4c0 fffff880`0105e533 : fffffa80`0cb1ec30 fffffa80`0cb1ec30 fffffa80`0a8716a8 fffffa80`0d970010 : fltmgr!GetContextFromStreamList+0x99
fffff880`02f8c540 fffff880`06a84ed9 : fffffa80`0cb1ec30 00000000`00000000 fffff880`02f8c618 fffff880`06a41b9c : fltmgr!FltGetStreamHandleContext+0x43
fffff880`02f8c570 fffffa80`0cb1ec30 : 00000000`00000000 fffff880`02f8c618 fffff880`06a41b9c fffffa80`0a64af68 : stflt+0x1ed9
fffff880`02f8c578 00000000`00000000 : fffff880`02f8c618 fffff880`06a41b9c fffffa80`0a64af68 fffff880`0106331a : 0xfffffa80`0cb1ec30
STACK_COMMAND: kb
FOLLOWUP_IP:
stflt+1ed9
fffff880`06a84ed9 ?? ???
SYMBOL_STACK_INDEX: 5
SYMBOL_NAME: stflt+1ed9
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: stflt
IMAGE_NAME: stflt.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4c2b57fc
FAILURE_BUCKET_ID: X64_0xD1_stflt+1ed9
2: kd> lmntsm
start end module name
fffff880`04556000 fffff880`04594000 1394ohci 1394ohci.sys Tue Jul 14 01:07:12 2009 (4A5BCC30)
fffff880`00f32000 fffff880`00f89000 ACPI ACPI.sys Tue Jul 14 00:19:34 2009 (4A5BC106)
fffff880`02d74000 fffff880`02dfe000 afd afd.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`045c1000 fffff880`045d7000 AgileVpn AgileVpn.sys Tue Jul 14 01:10:24 2009 (4A5BCCF0)
fffff880`00c2a000 fffff880`00c35000 amdxata amdxata.sys Tue May 19 18:56:59 2009 (4A12F2EB)
fffff880`04180000 fffff880`04188000 AppleCharger AppleCharger.sys Mon Jan 10 09:57:29 2011 (4D2AD809)
fffff880`06a7a000 fffff880`06a83000 aswFsBlk aswFsBlk.SYS Wed Feb 23 14:54:56 2011 (4D651FC0)
fffff880`06a40000 fffff880`06a7a000 aswMonFlt aswMonFlt.sys Wed Feb 23 14:55:04 2011 (4D651FC8)
fffff880`02c00000 fffff880`02c0a000 aswRdr aswRdr.SYS Wed Feb 23 14:55:11 2011 (4D651FCF)
fffff880`02c2f000 fffff880`02caf000 aswSnx aswSnx.SYS Wed Feb 23 14:56:59 2011 (4D65203B)
fffff880`04135000 fffff880`04180000 aswSP aswSP.SYS Wed Feb 23 14:57:02 2011 (4D65203E)
fffff880`02d64000 fffff880`02d74000 aswTdi aswTdi.SYS Wed Feb 23 14:55:51 2011 (4D651FF7)
fffff880`00ff1000 fffff880`00ffa000 atapi atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00c00000 fffff880`00c2a000 ataport ataport.SYS Tue Jul 14 00:19:52 2009 (4A5BC118)
fffff960`00890000 fffff960`008f1000 ATMFD ATMFD.DLL unavailable (00000000)
fffff880`02cb8000 fffff880`02cbf000 Beep Beep.SYS Tue Jul 14 01:00:13 2009 (4A5BCA8D)
fffff880`04124000 fffff880`04135000 blbdrive blbdrive.sys Tue Jul 14 00:35:59 2009 (4A5BC4DF)
fffff880`07721000 fffff880`0773f000 bowser bowser.sys Tue Jul 14 00:23:50 2009 (4A5BC206)
fffff880`045d7000 fffff880`045f3000 bridge bridge.sys Tue Jul 14 02:01:48 2009 (4A5BD8FC)
fffff960`00770000 fffff960`00797000 cdd cdd.dll unavailable (00000000)
fffff880`01968000 fffff880`01992000 cdrom cdrom.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`00d04000 fffff880`00dc4000 CI CI.dll Tue Jul 14 02:32:13 2009 (4A5BE01D)
fffff880`01902000 fffff880`01932000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00ca6000 fffff880`00d04000 CLFS CLFS.SYS Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`01124000 fffff880`01197000 cng cng.sys Tue Jul 14 00:49:40 2009 (4A5BC814)
fffff880`045aa000 fffff880`045ba000 CompositeBus CompositeBus.sys Tue Jul 14 01:00:33 2009 (4A5BCAA1)
fffff880`06da1000 fffff880`06daf000 crashdmp crashdmp.sys Tue Jul 14 01:01:01 2009 (4A5BCABD)
fffff880`04083000 fffff880`04106000 csc csc.sys Tue Jul 14 00:24:26 2009 (4A5BC22A)
fffff880`04106000 fffff880`04124000 dfsc dfsc.sys Tue Jul 14 00:23:44 2009 (4A5BC200)
fffff880`04074000 fffff880`04083000 discache discache.sys Tue Jul 14 00:37:18 2009 (4A5BC52E)
fffff880`018ec000 fffff880`01902000 disk disk.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`06d79000 fffff880`06d9b000 drmk drmk.sys Tue Jul 14 02:01:25 2009 (4A5BD8E5)
fffff880`06dbb000 fffff880`06dc4000 dump_atapi dump_atapi.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06daf000 fffff880`06dbb000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`06dc4000 fffff880`06dd7000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
fffff880`06dd7000 fffff880`06de3000 Dxapi Dxapi.sys Tue Jul 14 00:38:28 2009 (4A5BC574)
fffff880`10aaa000 fffff880`10b9e000 dxgkrnl dxgkrnl.sys Wed Jan 26 04:22:56 2011 (4D3FA1A0)
fffff880`10b9e000 fffff880`10be4000 dxgmms1 dxgmms1.sys Wed Jan 26 04:22:12 2011 (4D3FA174)
fffff880`08000000 fffff880`08036000 fastfat fastfat.SYS Tue Jul 14 00:23:28 2009 (4A5BC1F0)
fffff880`04594000 fffff880`045a1000 fdc fdc.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`010a6000 fffff880`010ba000 fileinfo fileinfo.sys Tue Jul 14 00:34:25 2009 (4A5BC481)
fffff880`04b11000 fffff880`04b1c000 flpydisk flpydisk.sys Tue Jul 14 01:00:54 2009 (4A5BCAB6)
fffff880`0105a000 fffff880`010a6000 fltmgr fltmgr.sys Tue Jul 14 00:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:19:45 2009 (4A5BC111)
fffff880`018b2000 fffff880`018ec000 fvevol fvevol.sys Tue Jul 14 00:22:15 2009 (4A5BC1A7)
fffff880`01400000 fffff880`0144a000 fwpkclnt fwpkclnt.sys Tue Jul 14 00:21:08 2009 (4A5BC164)
fffff880`0813d000 fffff880`08146000 gdrv gdrv.sys Fri Mar 13 03:22:29 2009 (49B9D175)
fffff880`08146000 fffff880`08150000 GVTDrv64 GVTDrv64.sys Tue Sep 05 08:10:02 2006 (44FD22CA)
fffff800`033ec000 fffff800`03435000 hal hal.dll Tue Jul 14 02:27:36 2009 (4A5BDF08)
fffff880`077f3000 fffff880`077ff000 hcmon hcmon.sys Thu Nov 11 19:44:25 2010 (4CDC4799)
fffff880`044cb000 fffff880`044ef000 HDAudBus HDAudBus.sys Tue Jul 14 01:06:13 2009 (4A5BCBF5)
fffff880`04bd6000 fffff880`04bef000 HIDCLASS HIDCLASS.SYS Tue Jul 14 01:06:21 2009 (4A5BCBFD)
fffff880`04bef000 fffff880`04bf7080 HIDPARSE HIDPARSE.SYS Tue Jul 14 01:06:17 2009 (4A5BCBF9)
fffff880`04bc8000 fffff880`04bd6000 hidusb hidusb.sys Tue Jul 14 01:06:22 2009 (4A5BCBFE)
fffff880`07659000 fffff880`07721000 HTTP HTTP.sys Tue Jul 14 00:22:16 2009 (4A5BC1A8)
fffff880`018a9000 fffff880`018b2000 hwpolicy hwpolicy.sys Tue Jul 14 00:19:22 2009 (4A5BC0FA)
fffff880`041ae000 fffff880`041c4000 intelppm intelppm.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
fffff880`0fe3c000 fffff880`0fe4b000 kbdclass kbdclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04a00000 fffff880`04a0e000 kbdhid kbdhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff800`00b9f000 fffff800`00ba9000 kdcom kdcom.dll Tue Jul 14 02:31:07 2009 (4A5BDFDB)
fffff880`08157000 fffff880`08161000 kerneld kerneld.amd64 Sat Sep 05 18:27:16 2009 (4AA29F74)
fffff880`04a4c000 fffff880`04a8f000 ks ks.sys Tue Jul 14 01:00:31 2009 (4A5BCA9F)
fffff880`013dd000 fffff880`013f7000 ksecdd ksecdd.sys Tue Jul 14 00:20:54 2009 (4A5BC156)
fffff880`015b1000 fffff880`015dc000 ksecpkg ksecpkg.sys Tue Jul 14 00:50:34 2009 (4A5BC84A)
fffff880`06d9b000 fffff880`06da0200 ksthunk ksthunk.sys Tue Jul 14 01:00:19 2009 (4A5BCA93)
fffff880`04a8f000 fffff880`04a92d80 LGBusEnum LGBusEnum.sys Tue Jul 14 23:34:45 2009 (4A5D0805)
fffff880`04a19000 fffff880`04a2c000 LHidFilt LHidFilt.Sys Fri Sep 21 12:05:39 2007 (46F3A583)
fffff880`04b72000 fffff880`04b87000 lltdio lltdio.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`045ba000 fffff880`045c1000 lmimirr lmimirr.sys Tue Apr 10 23:32:45 2007 (461C108D)
fffff880`07d2b000 fffff880`07d3e000 LMIRfsDriver LMIRfsDriver.sys Mon Jul 14 17:26:56 2008 (487B7E50)
fffff880`04a39000 fffff880`04a4c000 LMouFilt LMouFilt.Sys Fri Sep 21 12:05:43 2007 (46F3A587)
fffff880`06a1d000 fffff880`06a40000 luafv luafv.sys Tue Jul 14 00:26:13 2009 (4A5BC295)
fffff880`00c4e000 fffff880`00c92000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Tue Jul 14 02:29:10 2009 (4A5BDF66)
fffff880`06de3000 fffff880`06df1000 monitor monitor.sys Tue Jul 14 00:38:52 2009 (4A5BC58C)
fffff880`10bf1000 fffff880`10c00000 mouclass mouclass.sys Tue Jul 14 00:19:50 2009 (4A5BC116)
fffff880`04a2c000 fffff880`04a39000 mouhid mouhid.sys Tue Jul 14 01:00:20 2009 (4A5BCA94)
fffff880`00dd4000 fffff880`00dee000 mountmgr mountmgr.sys Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`0773f000 fffff880`07757000 mpsdrv mpsdrv.sys Tue Jul 14 01:08:25 2009 (4A5BCC79)
fffff880`07757000 fffff880`07783000 mrxsmb mrxsmb.sys Tue Jul 14 00:23:59 2009 (4A5BC20F)
fffff880`07783000 fffff880`077d0000 mrxsmb10 mrxsmb10.sys Tue Jul 14 00:24:08 2009 (4A5BC218)
fffff880`077d0000 fffff880`077f3000 mrxsmb20 mrxsmb20.sys Tue Jul 14 00:24:05 2009 (4A5BC215)
fffff880`02d1d000 fffff880`02d28000 Msfs Msfs.SYS Tue Jul 14 00:19:47 2009 (4A5BC113)
fffff880`00f92000 fffff880`00f9c000 msisadrv msisadrv.sys Tue Jul 14 00:19:26 2009 (4A5BC0FE)
fffff880`010c6000 fffff880`01124000 msrpc msrpc.sys Tue Jul 14 00:21:32 2009 (4A5BC17C)
fffff880`04069000 fffff880`04074000 mssmbios mssmbios.sys Tue Jul 14 00:31:10 2009 (4A5BC3BE)
fffff880`01897000 fffff880`018a9000 mup mup.sys Tue Jul 14 00:23:45 2009 (4A5BC201)
fffff880`0145f000 fffff880`01551000 ndis ndis.sys Tue Jul 14 00:21:40 2009 (4A5BC184)
fffff880`04424000 fffff880`04430000 ndistapi ndistapi.sys Tue Jul 14 01:10:00 2009 (4A5BCCD8)
fffff880`04430000 fffff880`0445f000 ndiswan ndiswan.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`04b1c000 fffff880`04b31000 NDProxy NDProxy.SYS Tue Jul 14 01:10:05 2009 (4A5BCCDD)
fffff880`02c1e000 fffff880`02c2d000 netbios netbios.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff880`01992000 fffff880`019d7000 netbt netbt.sys Tue Jul 14 00:21:28 2009 (4A5BC178)
fffff880`01551000 fffff880`015b1000 NETIO NETIO.SYS Tue Jul 14 00:21:46 2009 (4A5BC18A)
fffff880`02d28000 fffff880`02d39000 Npfs Npfs.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`0405d000 fffff880`04069000 nsiproxy nsiproxy.sys Tue Jul 14 00:21:02 2009 (4A5BC15E)
fffff800`02e0f000 fffff800`033ec000 nt ntkrnlmp.exe Tue Jul 14 00:40:48 2009 (4A5BC600)
fffff880`0123a000 fffff880`013dd000 Ntfs Ntfs.sys Tue Jul 14 00:20:47 2009 (4A5BC14F)
fffff880`02caf000 fffff880`02cb8000 Null Null.SYS Tue Jul 14 00:19:37 2009 (4A5BC109)
fffff880`10aa8000 fffff880`10aa9180 nvBridge nvBridge.kmd Sat Jan 08 01:57:22 2011 (4D27C482)
fffff880`0fe4d000 fffff880`10aa7d00 nvlddmkm nvlddmkm.sys Sat Jan 08 02:07:22 2011 (4D27C6DA)
fffff880`019d7000 fffff880`019fd000 pacer pacer.sys Tue Jul 14 01:09:41 2009 (4A5BCCC5)
fffff880`00fdc000 fffff880`00ff1000 partmgr partmgr.sys Tue Jul 14 00:19:58 2009 (4A5BC11E)
fffff880`00f9c000 fffff880`00fcf000 pci pci.sys Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`00e71000 fffff880`00e78000 pciide pciide.sys Tue Jul 14 00:19:49 2009 (4A5BC115)
fffff880`00dc4000 fffff880`00dd4000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000 pcw pcw.sys Tue Jul 14 00:19:27 2009 (4A5BC0FF)
fffff880`07d3e000 fffff880`07de4000 peauth peauth.sys Tue Jul 14 02:01:19 2009 (4A5BD8DF)
fffff880`06d3c000 fffff880`06d79000 portcls portcls.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00c92000 fffff880`00ca6000 PSHED PSHED.dll Tue Jul 14 02:32:23 2009 (4A5BE027)
fffff880`010ba000 fffff880`010c5e00 PxHlpa64 PxHlpa64.sys Wed Jun 24 00:16:35 2009 (4A416253)
fffff880`07d24000 fffff880`07d2b000 RaInfo RaInfo.sys Fri Jan 04 18:57:14 2008 (477E818A)
fffff880`04400000 fffff880`04424000 rasl2tp rasl2tp.sys Tue Jul 14 01:10:11 2009 (4A5BCCE3)
fffff880`0fe00000 fffff880`0fe1b000 raspppoe raspppoe.sys Tue Jul 14 01:10:17 2009 (4A5BCCE9)
fffff880`0fe1b000 fffff880`0fe3c000 raspptp raspptp.sys Tue Jul 14 01:10:18 2009 (4A5BCCEA)
fffff880`041c4000 fffff880`041de000 rassstp rassstp.sys Tue Jul 14 01:10:25 2009 (4A5BCCF1)
fffff880`0400c000 fffff880`0405d000 rdbss rdbss.sys Tue Jul 14 00:24:09 2009 (4A5BC219)
fffff880`045f3000 fffff880`045fe000 rdpbus rdpbus.sys Tue Jul 14 01:17:46 2009 (4A5BCEAA)
fffff880`02d02000 fffff880`02d0b000 RDPCDD RDPCDD.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d0b000 fffff880`02d14000 rdpencdd rdpencdd.sys Tue Jul 14 01:16:34 2009 (4A5BCE62)
fffff880`02d14000 fffff880`02d1d000 rdprefmp rdprefmp.sys Tue Jul 14 01:16:35 2009 (4A5BCE63)
fffff880`0185d000 fffff880`01897000 rdyboost rdyboost.sys Tue Jul 14 00:34:34 2009 (4A5BC48A)
fffff880`04b87000 fffff880`04b9f000 rspndr rspndr.sys Tue Jul 14 01:08:50 2009 (4A5BCC92)
fffff880`044ef000 fffff880`04556000 Rt64win7 Rt64win7.sys Thu Jan 13 11:57:19 2011 (4D2EE89F)
fffff880`06ad2000 fffff880`06d3b800 RTKVHD64 RTKVHD64.sys Tue Nov 02 11:25:59 2010 (4CCFF547)
fffff880`04b9f000 fffff880`04bab000 RtNdPt60 RtNdPt60.sys Mon Jul 20 03:27:32 2009 (4A63D614)
fffff880`0182f000 fffff880`01849000 SCDEmu SCDEmu.SYS Mon Apr 12 09:52:25 2010 (4BC2DF49)
fffff880`07de4000 fffff880`07def000 secdrv secdrv.SYS Wed Sep 13 14:18:38 2006 (4508052E)
fffff880`06df1000 fffff880`06dfa000 sfloppy sfloppy.sys Tue Jul 14 01:01:02 2009 (4A5BCABE)
fffff880`01000000 fffff880`01046000 snapman snapman.sys Sat Apr 10 10:16:30 2010 (4BC041EE)
fffff880`015dc000 fffff880`015e4000 spldr spldr.sys Mon May 11 17:56:27 2009 (4A0858BB)
fffff880`080a5000 fffff880`0813d000 srv srv.sys Tue Jul 14 00:25:11 2009 (4A5BC257)
fffff880`0803c000 fffff880`080a5000 srv2 srv2.sys Tue Jul 14 00:25:02 2009 (4A5BC24E)
fffff880`07c00000 fffff880`07c2d000 srvnet srvnet.sys Tue Jul 14 00:24:58 2009 (4A5BC24A)
fffff880`06a83000 fffff880`06aaf000 stflt stflt.sys Wed Jun 30 15:43:08 2010 (4C2B57FC)
fffff880`045fe000 fffff880`045ff480 swenum swenum.sys Tue Jul 14 01:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000 tcpip tcpip.sys Tue Jul 14 00:25:34 2009 (4A5BC26E)
fffff880`07c2d000 fffff880`07c3f000 tcpipreg tcpipreg.sys Tue Jul 14 01:09:49 2009 (4A5BCCCD)
fffff880`02d57000 fffff880`02d64000 TDI TDI.SYS Tue Jul 14 00:21:18 2009 (4A5BC16E)
fffff880`02d39000 fffff880`02d57000 tdx tdx.sys Tue Jul 14 00:21:15 2009 (4A5BC16B)
fffff880`0181b000 fffff880`0182f000 termdd termdd.sys Tue Jul 14 01:16:36 2009 (4A5BCE64)
fffff960`00500000 fffff960`0050a000 TSDDD TSDDD.dll unavailable (00000000)
fffff880`04188000 fffff880`041ae000 tunnel tunnel.sys Tue Jul 14 01:09:37 2009 (4A5BCCC1)
fffff880`04a93000 fffff880`04aa5000 umbus umbus.sys Tue Jul 14 01:06:56 2009 (4A5BCC20)
fffff880`04bab000 fffff880`04bc8000 usbccgp usbccgp.sys Tue Jul 14 01:06:45 2009 (4A5BCC15)
fffff880`06a1b000 fffff880`06a1cf00 USBD USBD.SYS Tue Jul 14 01:06:23 2009 (4A5BCBFF)
fffff880`044ba000 fffff880`044cb000 usbehci usbehci.sys Tue Jul 14 01:06:30 2009 (4A5BCC06)
fffff880`04ab7000 fffff880`04b11000 usbhub usbhub.sys Tue Jul 14 01:07:09 2009 (4A5BCC2D)
fffff880`04464000 fffff880`044ba000 USBPORT USBPORT.SYS Tue Jul 14 01:06:31 2009 (4A5BCC07)
fffff880`06a00000 fffff880`06a1b000 USBSTOR USBSTOR.SYS Tue Jul 14 01:06:34 2009 (4A5BCC0A)
fffff880`10be4000 fffff880`10bf1000 usbuhci usbuhci.sys Tue Jul 14 01:06:27 2009 (4A5BCC03)
fffff880`00fcf000 fffff880`00fdc000 vdrvroot vdrvroot.sys Tue Jul 14 01:01:31 2009 (4A5BCADB)
fffff880`02cbf000 fffff880`02ccd000 vga vga.sys Tue Jul 14 00:38:47 2009 (4A5BC587)
fffff880`02ccd000 fffff880`02cf2000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:38:51 2009 (4A5BC58B)
fffff880`07600000 fffff880`07618000 vmci vmci.sys Thu Nov 11 19:11:58 2010 (4CDC3FFE)
fffff880`04a0e000 fffff880`04a19000 VMkbd VMkbd.sys Thu Nov 11 20:35:18 2010 (4CDC5386)
fffff880`04aad000 fffff880`04ab7000 VMNET VMNET.SYS Mon Aug 10 13:04:50 2009 (4A800CE2)
fffff880`04aa5000 fffff880`04aad000 vmnetadapter vmnetadapter.sys Mon Aug 10 13:04:53 2009 (4A800CE5)
fffff880`04b62000 fffff880`04b72000 vmnetbridge vmnetbridge.sys Mon Aug 10 13:05:58 2009 (4A800D26)
fffff880`07c3f000 fffff880`07c49000 vmnetuserif vmnetuserif.sys Thu Nov 11 19:59:16 2010 (4CDC4B14)
fffff880`0144a000 fffff880`0145a000 vmstorfl vmstorfl.sys Tue Jul 14 00:42:54 2009 (4A5BC67E)
fffff880`07c4e000 fffff880`07d24000 vmx86 vmx86.sys Thu Nov 11 21:23:08 2010 (4CDC5EBC)
fffff880`00e00000 fffff880`00e15000 volmgr volmgr.sys Tue Jul 14 00:19:57 2009 (4A5BC11D)
fffff880`00e15000 fffff880`00e71000 volmgrx volmgrx.sys Tue Jul 14 00:20:33 2009 (4A5BC141)
fffff880`01197000 fffff880`011e3000 volsnap volsnap.sys Tue Jul 14 00:20:08 2009 (4A5BC128)
fffff880`07def000 fffff880`07dfb000 vstor2_ws60 vstor2-ws60.sys Thu Aug 19 21:28:39 2010 (4C6D93F7)
fffff880`01800000 fffff880`0181b000 wanarp wanarp.sys Tue Jul 14 01:10:21 2009 (4A5BCCED)
fffff880`02cf2000 fffff880`02d02000 watchdog watchdog.sys Tue Jul 14 00:37:35 2009 (4A5BC53F)
fffff880`00e7f000 fffff880`00f23000 Wdf01000 Wdf01000.sys Tue Jul 14 00:22:07 2009 (4A5BC19F)
fffff880`00f23000 fffff880`00f32000 WDFLDR WDFLDR.SYS Tue Jul 14 00:19:54 2009 (4A5BC11A)
fffff880`02c15000 fffff880`02c1e000 wfplwf wfplwf.sys Tue Jul 14 01:09:26 2009 (4A5BCCB6)
fffff960`00080000 fffff960`0038f000 win32k win32k.sys unavailable (00000000)
fffff880`08150000 fffff880`08157000 WinRing0x64 WinRing0x64.sys Sat Jul 26 14:29:37 2008 (488B26C1)
fffff880`045a1000 fffff880`045aa000 wmiacpi wmiacpi.sys Tue Jul 14 00:31:02 2009 (4A5BC3B6)
fffff880`00f89000 fffff880`00f92000 WMILIB WMILIB.SYS Tue Jul 14 00:19:51 2009 (4A5BC117)
fffff880`02c0a000 fffff880`02c15000 ws2ifsl ws2ifsl.sys Tue Jul 14 01:10:33 2009 (4A5BCCF9)
fffff880`06aaf000 fffff880`06ad0000 WudfPf WudfPf.sys Tue Jul 14 01:05:37 2009 (4A5BCBD1)
fffff880`04b31000 fffff880`04b62000 WUDFRd WUDFRd.sys Tue Jul 14 01:06:06 2009 (4A5BCBEE)
Unloaded modules:
fffff880`08161000 fffff880`081d2000 spsys.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
fffff880`01932000 fffff880`01940000 crashdmp.sys
Checksum: 00000000
fffff880`01940000 fffff880`0194c000 dump_ataport
Checksum: 00000000
fffff880`0194c000 fffff880`01955000 dump_atapi.s
Checksum: 00000000
fffff880`01955000 fffff880`01968000 dump_dumpfve
Checksum: 00000000
fffff880`04add000 fffff880`04b0e000 WUDFRd.sys
Checksum: 00000000
fffff880`04a68000 fffff880`04a99000 WUDFRd.sys
Checksum: 00000000
Very likely imagination.Both hard drives passed the tests. Also after adjusting the ram settings as redduc900 suggested my computer seems to be running a bit faster, or it could be just my imagination lol.
Thank you very much dan_ep82
Yes I had Spyware Terminator installed, as soon as I read your post I uninstalled it.
I also ran the test from the sevenforums. I zipped the folder, it can be downloaded here (Windows_NT6_BSOD_jcgriff2).
Its interesting, I've been running this setup for some time now without any problems until last month.
SP1 upgrade coming later today
fffff880`02f8c1e8 fffff800`02ec7469 : 00000000`0000000a fffff8a0`04fed708 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffff880`02f8c1f0 fffff800`02ec60e0 : fffff880`02f8d000 00000000`00000000 00000000`00000000 fffff880`03704104 : nt!KiBugCheckDispatch+0x69
fffff880`02f8c330 fffff880`010a2fa9 : 00000000`00000000 00000000`00000000 fffff880`02f8c570 fffff880`010a232e : nt!KiPageFault+0x260
fffff880`02f8c4c0 fffff880`010a2533 : fffffa80`0c62e600 fffffa80`0c62e600 fffffa80`0a8526a8 fffffa80`0cf35010 : fltmgr!GetContextFromStreamList+0x99
fffff880`02f8c540 fffff880`04d9ced9 : fffffa80`0c62e600 00000000`00000000 fffff880`02f8c618 fffff880`04d62b9c : fltmgr!FltGetStreamHandleContext+0x43
fffff880`02f8c570 fffffa80`0c62e600 : 00000000`00000000 fffff880`02f8c618 fffff880`04d62b9c fffffa80`0e5bff68 :[B][COLOR="Red"] stflt+0x1ed9[/COLOR][/B]
fffff880`02f8c578 00000000`00000000 : fffff880`02f8c618 fffff880`04d62b9c fffffa80`0e5bff68 fffff880`010a731a : 0xfffffa80`0c62e600
Event[1183]:
Log Name: System
Source: BridgeMP
Date: 2011-04-15T19:47:42.997
Event ID: 14702
Task: N/A
Level: Error
Opcode: N/A
Keyword: Classic
User: N/A
User Name: N/A
Computer: CMI7920
Description:
Bridge [Adapter Realtek PCIe GBE Family Controller]:
The bridge could not modify the network adapter's packet filter. The network adapter will not function correctly.
If uninstalling that program doesn't fix it, we might try a clean install next.
Cool. Good call, dan!Thank you very much for investing some of your spare time to look into this issue.
Sorry for the delay in my reply, I was out of town for few days. I've upgraded to SP1 and uninstalled spyware teminator. To be honest I've never thought that it would be that program causing all the issues. I installed the latest drivers for gigabyte for their motherboard. I guess their realtek drivers are a bit out of date lol. I will most certainly update it as soon as i get home I will also run driver verifier to make sure there is no other problems, will post results.
Thank you once again!
Mike
