- Dec 27, 2008
Yes, the device you show in post #94 is the breaker panel. It may well be that the whole house is tied to that breaker panel and if so then a power line network adapter should work.
I would check it this way: Go to the outlets that the two units of the pair would be plugged into. Plug something - anything- into each outlet. Go to the breaker panel and try and identify the breaker or breakers that serve those two outlets. They might be labeled but if not you would need to employ trial and error to identify the correct one or ones. Power down any plugged in computers. Throw the breakers and see if your plugged in devices quit. If you can cut power to said outlets with breakers that are in the same breaker panel then those outlets are being served by the same breaker panel.
Hopefully, the circuit is not too long to use a power line network adapter. I think most of them say that 300' of wiring is the limit of their reach. If this is an apartment and the two outlets in question are on the same breaker panel then the circuit ought to be fairly short.
By the way the base station of the network adapter pair will need to be plugged into an outlet near the router as the base station will connect to the router via ethernet cable. The power line network adapters should be plugged directly into an outlet rather than into a power strip.
