- Jan 12, 2013
- on your window sill staring at you
what I am more suprised about is that there are not more drawings of the case with fans. any resons?
Why would there be more of that? Its pretty easy to conceptualize with words, to me, what the airflow is doing... its a lot quicker to type than to make a terrible MSPaint (well, IM terrible at Paint, LOL!)what I am more suprised about is that there are not more drawings of the case with fans. any resons?
I currently run my main computer with positive pressure (230 CFM in/180 CFM out), I've had it as high as 300 CFM in/180 CFM out. I've got it on a fan controller, so I can balance the airflow however I like by shutting off fans or choosing between high/low speed.
you don't have either! you have a damn hurricane in that thing!
Lets say a case has 3 intake fans rated 73.6cfm @ 1300rpm with no restriction. Drop that to 700rpm with grill, filter, HDD cage, GPU cabling, and back grill and
I'm maybe moving 20-60cfm through the case..
So how much air is that 200-300cfm fan setup really moving?
Indeed.
So how much air is a 200-300cfm fan setup really moving with no filters? Is it enough to completely change the air in a 10' x10' room every 3-4 minutes.?
Edit: It's fun to talk about it. Main thing is that it does what you want it to do.
That really depends on the fan. If it's a benching setup, yes. I used three taped together and stuck in a window to ventilate my whole house a couple summers ago. They'd pull the door open if it wasn't latched. Pulled the catdoor open too.
