I know a guy who can get us some JouJyes...
Why does this sound like we're druggies and not computer geeks?
I'm just waiting to hit the 100 post-count now- already flew way past the required 20 points on HWBot! Unless you can sneak me in early, I guess I better stop benching and reply to more threads.....
Man do I need to get some proper gear to go around my components. I'm still using >$40 cases and run all Rosewill RFX-120 fans at the moment ($4.99 each baby!). The airflow is impressive compared to anything else for the price, especially with 2-ball bearings and not just sleeve, but I'm assuming there is a reason most people spend more than a five-spot on their fans.
Thanks for the tips you guys. Either of you have any opinon on which of those models is as close to silent as you could get for a 120mm front intake and matching rear exhaust? I don't need to move a ton of air- it's only cooling a 95w Athlon X3 and a 6670 with a big passive heatsink attached. Noctua has always been the company I presume to be the quietest, but considering how little airflow I need (easily <42cfm my logisys rates at), maybe there are better options...
I keep thinking about going 100% fanless, but I assume that passive heatsinks assume there is going to be air circulation from some other source. Passive PSU/CPU/GPU and no case fans probably wouldn't last too long...
Ideally, one would want neutral pressure (just as much air being sucked in as there is being blown out)
Mostly agree.I agree with this. Pressure isn't a great measurement. You don't want pressure, you want flow.
Pressurising your case, will force air out of any/all gaps and cracks.
Similarly
De-pressurings your case will have air been drawn in from random places.
You want to control the direction of the airflow so that it flows smoothly through your case and reaches the vital areas, not just churns until it finds a way out. When cooling, quantity of air is more important then its quality.
Filters do restrict but to me the advantage far outweighs the disadvantage. My filters need cleaned weekly.. Takes seconds. It's part of vacuuming the room. Pop off, vacuum, back on. So much easier and faster than having to move case up onto desk, open it all up, remove cooler fans to clean fins.. and don't even want to think about cleaning GPU.Ducting plays nice with the hr-02 + single fan + no grill in the back.
Filters are going to kill the airflow unless they are super good quality though, I'd probably ditch them for something like that and dust the thing regularly.
