- Nov 28, 2001
I have a EVGA 800 G2 and for some time now, it has been giving trouble when powering back on after a power loss (loss of power from wall outlet). This can be me simply turning off the power supply with the built in power switch on the PSU. After losing power, I will spend minutes switching it off and on till it finally powers up, after which, it never has problems powering on or off via the case/motherboard power switch. I've no clue what could be causing the problem (I have not opened it up), and the amount of time and the number of switching of the on/off switch, as well as how long I leave it in the off or on position does not seem to matter. I have a number of USB devices plugged in, which will power up once the PSU starts to deliver power, at which point I know to stop toggling the power switch. I've tested the voltages as well as monitored it via software (I know they are not 100% accurate, but they are fairly close for my board), and I do not see anything out of spec. It's powering the system in my signature, so it doesn't have problems delivering the amps when needed.
Anyone care to guess what could be the problem with the PSU? Anyone ever had similar problems?
