Another consideration, in addition to the GPU, will now be the motherboard. Several of the X670(E) (and maybe B650) boards support front 60W Type-C PD connectors. You will need an additional 6-pin PCIe cable to power this, leaving you only 1x 8-pin cable to power whatever GPU you do use.
Are you asking a question? We don't know your other components so we couldn't answer even if we wanted to. But we can say if the PSU is not powerful enough, it is unlikely to be due to the CPU.Hm...
So it sounds like my old school PSU will not be enough for connector reasons, rather than power handling reasons?
You can also use a molex to 6-pin adapter and leave the two pcie connectors for whatever gpu you have/plan to buy.Hm...
I'm running a 12900k (up to 241W) and a 3090ti (450w) with a 850w psu.
Since the power limit is for the socket, if one part uses less, other parts can use more and still bounce off the limiter. What's the stock PPT ratio again? I think it is 35% over TDP, so at stock these could pull up to 230W. That 5.7 GHz needs it power from somewhere!I assume that the higher TDP is because of integrated graphics, so with the discrete graphics card, it can be lower.
That GPU may/may not work. If you decide to use it, update it's BIOS first just in case it isn't compatible with UEFI. That said, if that's how you game, I don't imagine you to need a high res high Hz capable card and a mid-range or budget card would suffice. To that end, your 750W is, without a doubt, plenty.I have not begun research on GPUs. I am upgrading a 2016 machine. I might use the GPU inside it....since I keep putting off gaming...., it's an XFX Double D FX-787A-CDBC Radeon HD 7870. I've been putting off Gaming since Sega Genesis.... I think I may have missed out on some games over the years...
For the most part, brand is a preference thing, really. Stick with the QVL list for the board you chose and any on the list should work. I prefer GSkill, like ADATA and Corsair. This is a new platform so some brands may have growing pains with certain boards (GSkill and Giga for Z690, for example).I probably need advice on RAM, which brand?
I always say get the best you can/want to afford. While a Ryzen 5 should be enough for now and a marked improvement over what you have, 6c/12t is already getting long in the tooth to me...however, it depends on how you use your PC. You hang onto your PC for quite a while, so, I'd go Ryzen 7 7700X (8c/16t). If you're still worried about the PSU (you aren't listening/shouldn't be, lol) these are both '105W' (+35%) CPUs.I am guessing you'd advise to stick with Ryzen 5 and not go for higher CPUs, can any be overclocked you think?
Ehh... I wouldn't bet on it. RM's, IIRC were higher quality than the Bronze PSUs.You know I do have a Corsair RM-850 PSU in now, but I am guessing all these years using it would make it inferior to unboxed EVGA SuperNova 750 B2 Bronze EVSB750.
How about you tell me a good 2022 GPU that is on the limit of what EVGA SuperNova 750 B2 Bronze EVSB750 can push.
I love my Hyte 60. It has a USB 3.2 Gen 2 (10 Gbps) port up front. I plug my portable drive in the back 20 Gbps port and it sits on top of the chassis.Oh and a computer case that has a superfast USB connector in upper front to connect the 12 inch Portable SSD cable to since those 12 inch cable do transfer many times faster than longer cheaper ones, and having those connectors in the back is a PITA to reach with a 12" cable.
Offhand, no idea... but if it fits AM4, it should fit AM5. Look at the specs page to see and/or contact Thermalright for confirmation. That said, the heatsink should handle the 105W processors fine, not so sure about the 170W+ ones though. For the latter, you may want to look into a 2x140 or 3x120mm AIO for best results.I have a Thermalright Ultra-120 eXtreme 1366 RT heatsink, will that work on 2022 AMD?
Doesn't he have peace of mind already? Literally, the only thing a quality and properly functioning 750W PSU won't cover are flagship/400W+ GPUs (generally over $700 - 4080 may change that...). If he's into 2560x1440/144 or 4k gaming, that's his market and buy a new PSU. Otherwise, any midrange card will be plenty for 1080p 144+ or 2560x1440 60+ easily. As mentioned previously (and in Nebs thread), I ran a 3090Ti and 12900K on a 750W PSU without issue...that's not ideal, but it worked just fine for a month or two before I upgraded to a more efficient model (gold to Titanium, 850W). Notice I 'only' have an 850W for the best O D best O D best parts?$550 for the CPU, $200ish for a new MB, $100ish for some RAM, $750+ for a GPU that *may* push you past what your 750w PSU can handle. What's another $150 for peace of mind?
Tough to say for this gen... the motherboards aren't out yet. All four major board partners generally produce quality products (everyone has duds and studs). It's a new platform so which one will have the least growing pains, no idea. Gigabyte was the black sheep for Z690 (memory woes out of the gate, notably better/not a worry now), but maybe they nail it with AM5. Kept shaking the Magic 8-ball and got these answers - "Answer unclear, ask later", "Can't say now", and "Consult me later".Thank you for thorough answers. I usually buy Asus, which mobo brands are now your personal picks in 2022?
Pretty sure I just addressed the quality aspect of that and didn't list one over the other. The 750W bronze is a budget PSU, new or w/e while the RM is higher quality out of the box (I wouldn't expect it to turn into a low-quality unit with use/time). I'd run either one...neither will kill your system if they die so it doesn't really matter.I am surprised that you seem to be saying you would opt for me to transfer my Corsair RM-850 that's been running most of the day for ten years vs. a brand new unboxed EVGA SuperNova 750 B2 Bronze EVSB750,, correct?
RM850: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=369
Supernova: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=393
The Corsair uses lower grade capacitors, but has slightly better ripple suppression vs the Supernova. Fan made a bit of noise during testing.
The Supernova has higher quality capacitors and the fan doesn't make a noise like the Corsair did for Jeremy. Ripple suppression on the 12v rail was 50mV which is good just not as good as we've seen in the past.
I vote for the Supernova. the point difference is a mere 0.2. The Corsair got 9.2 and the Supernova got 9. Should have gotten more but points IMO, but points were deducted for being semi-modular. I have 2 Supernova PSU's in the house and they are both of very high quality. I won't ever buy another brand for PSU's again.
Also, woe, look wut I found on the internets
AM5 Motherboard prices:
* X670E: $350 – $500
* X670: $270– $350
* B650E: $230 – $330
* B650: $130 – $230
