- Thread Starter
- #41
Playing around and benching the chip will teach you a lot about your setup. I learned more from benching my system then I ever would have just shooting for a stable Oc. Yes you can run any Fx chip on the Sabertooth as a matter of fact that run on Dice with my 6300 was on my Sabertooth. That said what types of gains are you looking for. Unless you're doing some serious multi threaded tasks that will utilize more cores then the Fx 6xxx has you will likely not see any gains performance wise. Additionally, if you stepped up to a Fx 8xxx you would have to deal with a lot more heat. So you would likely not be able to run the same Oc on the Fx 8xxx as you can on the Fx 6xxx.
Ah yeah I gotcha. No I don't do anything that will require more cores than what I have now. Use my comp for everyday use and then online gaming, Iracing. Very CPU heavy game.
Side note I bumped the HT speed up to 2600 and just to see I let it run prime while I slept. No errors. May try the CPU/NB frequency too.
