Correct me if I'm wrong but can you even do a base clock of 290 on an Athlon 64x2? I thought it had problems going above a certain base clock.
I see what you mean.when i make fsb 220 and multiplier to x10 it's 2.2 ghz but when i make fsb 260 and multiplier to x10 it's 2 ghz.should i update bios ?
Yeah, it is possible that it ends up running 200 x 10.Sure update the bios.
What do you mean when you say you set FSB 260 times 10 and you get 2.0Ghz and not 2.6Ghz. Do you see the 2.0Ghz after you set 260x10 and Save and Exit the bios and the board then boots at 2.0Ghz.
If that is when you see 260 x 10 become only 2.0Ghz then the board is saving itself by setting lower speed since the bios believes it cannot run at 260x10 and resets itself lower. Seen that happen on motherboards before. Especially some of the cheaper models. We don't even know what board you have and we are pretty far into this thread with only little information about your system. That is not normally good.
EDIT:
Okay I found the motherboard you are using. You do not have a signature where the system can follow your every post. I had to go back to the top of the thread and read every post until I found >> Biostar TA690G Motherboard in one of your posts. Now can do some g00gling about that motherboard.
END EDIT.
