- May 28, 2005
- Tigard, Oregon
- Thread Starter
- #61
shawkins said:Alright, thats enough work for one evening/night so im off to bed. I am hoping to get the holes for the RAD cut and get it installed tomorrow, but that may not happen.
Hows she look though?
Thanks!
Ya, I would have used delta's, but I got a really good deal on the Panaflo's. Maybe Ill upgrade? Where do you get yours at? Also, where did you get your Matrix front panel your using on your project, I want one for this thing!Electron Chaser said:Looks great and yeah Delta fans would have made it that much better. LOL
Thanks!twoeyes said:neato
Actually, I am buying the hardware last, so from the looks of the new Intel CPU's coming out, it may end up being Intel based!markodude said:Keep it coming man this is looking like a beast of a project, shame it was not Intel based especially with all that blue!
Subscribed!
Yes I did. I used a nail a little smaller then the rod first spreading the fins a little bit. Then I sued a nail the same size as the rod to spread them right right ammount. I tested it for leaks after I used the small nail, but havent tested it for leaks after using the big nail yet. I also did have to drill out the holes for the 6-32 rods, since they were beigger then the holes.ShellMaza said:Question, Did You Run The Screws All The Way Thru The Rad? I Have The 120mmx3 Version And I Seen No Way To Run Them All The Way Thru....
