- May 28, 2005
- Tigard, Oregon
- Thread Starter
- #81
I made this bracket because its the only way that I could figure out of how to mount the PSU with my huge fan contraption on it. What I will do, is cut a hole in the back of the case just a hair larger then the PSU. With this bracket bolted on the PSU, the PSU will slide in and I can screw this bracket to the case. It will also be easier to remove the PSU as all I have to do is un hook the wires, and unscrew 4 screws and it will slide right out the back!
Another pic try to sort of explain what I mean:
EDIT: Ignore the writing on the bracket, it doesnt have anything to do with what I was explaining. It is for making the bracket.
