- Jan 5, 2013
- Tampa, FL
I'm doing a scratch build for a new computer. I am doing an all blue theme and calling it Project "Cold Reality". These are the parts I am tentatively going to buy.
New Computer:
Mother Board
ASUS P9X79 PRO LGA 2011 Intel X79
CPU
Intel Core i7-3930K
RAM
G.SKILL Ripjaws Z Series 16GB (4 x 4GB) DDR3 2133
Graphics
EVGA GeForce GTX 780 Hydro Copper
Blu-Ray Burner
LITE-ON Black Blu-ray Burner with Blu Ray 3D Feature - OEM
Power Supply
SILVERSTONE ST1000-P 1000W 80 PLUS SILVER Certified Modular Power Supply
Case
Corsair Obsidian Series 900D
Water Cooling:
CPU Block
CPU-380I Water Block
Pump
Swiftech MCP35X
Reservoir
MPC35X Reservoir
Pump Heat Sink
Swiftech MCP35X Series Heat Sink
Radiator
XSPC RX360
XSPC RX240
Fans
5X Scythe Gentle Typhoon 120 mm AP-15
Tubing
PrimoFlex Advanced LRT 10ft Tubing - 1/2in. ID X 3/4in. OD - Brilliant UV Blue
SLI Fittings
Bitspower BP-DG14AALPII Silver Shining Dual G1/4" Adjustable Aqua Link Pipe II (41-69mm)
Fittings
16X Bitspower Premium G1/4" High Flow 1/2" Fitting
Quick Disconnect Fittings
Koolance QD3 Quick Disconnect No-Spill Coupling, Female Barb for ID 13mm (1/2in)
2XKoolance QD3 Quick Disconnect No-Spill Coupling, Male Barb for ID 13mm (1/2in)
TIM
Shin-Etsu X23-7783D Silicone Thermal Compound - 1g
Biocide
Petra's Tech Nuke PHN Concentrated Biocide (10mL)
Fan Cables
5-way Splitter Akasa FLEXA FP5S PWM Fan Splitter Cable
Fan Controller
Lamptron FC-3- "A" Edition 30 Watts Per Channel
This should be my complete parts list. I'll be ordering in probably a month or so, and begin assembly about that time. In addition to this computer, I'm also planning on building a computer desk as well, so keep a look out for the build logs! If you see something that I'm missing, please let me know. Thank you again for all the help and for helping me make this project happen.
New Computer:
Mother Board
CPU
Intel Core i7-3930K
RAM
Graphics
Blu-Ray Burner
Power Supply
Case
Water Cooling:
CPU Block
Pump
Swiftech MCP35X
Reservoir
MPC35X Reservoir
Pump Heat Sink
Radiator
XSPC RX360
XSPC RX240
Fans
Tubing
SLI Fittings
Fittings
TIM
Biocide
Fan Cables
Fan Controller
