*UPDATE*
KK well i cut my side panel up, i guess im done with it (other side panel)
Cut my 120mm blow hole for the cpu
As you can see the blow hole doesnt match up with the hole on the mobo tray
i was retarded and the hole on the tray i didnt measure right, so im just gonna widen the hole on the tray as much as i can. So ill have a big useless hole on my mobo tray
Also...........................
I got my psone lcd on saturday, $30 shipped, 18 bucks plus12 shipping. Thanx Iamgoodyy from Bit-tech.net!!
nice box, lets open it up
Screen and adapter
Woot my desktop
Pshh, i dled along came polly off someones comp at the lan party on friday (18th) and woot its jennifer anistons ***
thats all for now
Anybody know how to hook it up to a molex without buying the Sony car adapter? could i use this thing?
http://www.allelectronics.com/cgi-bin/category.cgi?category=search&item=CLP-59&type=store
So i could attach the part youd plug into the cell phone to the lcd, and what just cut off the cigarette lighter plug and attach a molex?? wouldnt that just be a straight connection to the psu?
edit: BTW the screen isnt hooked up to vga yet, i just hooked it up through composite using the composite cable thing from my camera
