- Apr 16, 2009
- Prince George, B.C.
- Thread Starter
- #41
hey man gotta keep them feet warm .
Been a little bit so here is an update all the hard tube is done. however there are a couple pieces i may try and re-do (100% chance of me getting too lazy to do that). because i didnt want to use any 90 degree fittings or such noncence i had to push the PETG to its bending limit in two places. See if you can spot em. I also had to take some time off fromt eh build to repair all the driveshaft U-joints and constant velocity joints in my jeeps drivetrain so i could drive to work.
Also i got the computer booted up for the first time and was having bad stability issues. at first i thought "F#^& i have to RMA a gpu that i have already painted." but after taking one car out and trying it with both 6+8 power cords i came to the conclusion that actually one of the 12 volt rails in my power supply is dead. plugged into one spot i loose video output the instant i apply a load like folding @ home or furmark. plugged into the other spot on the power supply its fine.
bending the most complicated piece of tubing in the build. (took me 2 trys before i gave up and ordered a bigger bending insert, size definatly matters)
PURPLE LIGHTS
BLUEISH CYAN LIGHTS
