- Oct 13, 2004
- Thread Starter
- #181
You should try and play with DPI settings.
It's really sad that the EEE PC VBIOS doesn't support 1000x600, that resolution would be sweet with a bigger DPI settings.
Ah that made a good difference. I find that 105 DPI and 800x600 is the best setting. 1024x768 at 120 DPI is readable, but it's not great....so I'll stick with 800x600 105 DPI.
Looks great!
Finally got your Eee!! Sweet!
You can stick with the 401 BIOS for right now so you can get everything installed, but then I recommend upgrading to the 0511 BIOS so you can get the brighter screen the option to overclock to 900MHz. It makes a pretty large difference in speed.
