- Jul 29, 2001
Ok unfortunately this didn't work.
i've been keepin an eye on these things, hows the battery life with it up to 900Mhz?
i've been thinking about em more and more because i may be getting a night job where i wont do much and i thought it would be cool to get one and a USB ATSC tuner to watch TV and be able to surf the net after letterman and craig go off.
Did you try to reinstall the ACPI driver?
Grrr having trouble getting my FN Keys to work. I did a reinstall and now they aren't working.
If you're using the 8804 Bios that's why. Use the 511 BIOS, change to performance mode then flash to the 801 that'll give you 900mhz and fix fan problems.
No but you see they were working fine. It stopped after i reformatted windows because it got corrupt. The stock OS crashes and locks up too. Something is wrong.
I'll let you guys know how the RMA goes.
I spoke to the tech guy on Friday (who was kinda rude) and he issued the RMA, I'm just waiting on an email from the RMA department for instructions.
so.....RMA Start: 2/23/08
let's see how long it takes.
my g/f's 8G is working perfect. Running a slight volt mod and oc to 1ghz. She uses it every day to take notes on and stuff and loves it.
But which BIOS are you using? If you're reinstalling using the 8804 the ACPI driver won't work.
Oh so its driver related, not BIOS related then? So the fact that the driver worked with the original BIOS, and wouldn't install with the 8804 BIOS made the difference?
Ok then let's try fixing this!
What BIOS should I flash to from this point?
EDIT: Flashed to the 0701 BIOS and FN keys work again!!! I LOVE YOU !
I wonder if I should now flash back to the 8804, or what other BIOS' have the 900MHz option?
Oh and someone upgraded the CPU in the EEE.
http://blog.tom.com/guryhwa1121/article/2915.html
If I can get the CPU I'll attempt it soon. Shouldn't be toooooo hard I figure heat gun and fast melting solder.
How'd you do the voltmod?
im working on a guide. when she comes home for spring break i'll finish the guide and take pics. I will tell you its not to easy.
Damn you guys have some cool stuff in yours!
I really want to put stuff into my Eee, but I don't want the warranty out the window just yet.
Is it reversible at all?
