have you checked for a bios update?
most motherboards require a bios update to run the fx cpu.
one other thing i have seen on new builds is installed cpu voltage being to low, stock should be about 1.35 volts.
you might also try resetting the rtc/cmos, that process is in your board manual.
good luck.
It is time for sure. Middle of someone else's thread and no idea what parts and pieces you have in the computer case.
Sigs are pretty easy. Signatures follow you in every post in the forum so your system information follows you and people know what is in the box.
Be logged in to the forum.
Across the top of the forum is a button shown as 'user cp'. Click that button.
On the page that loads are a list of options down the left side of the page.
Under the Settings & Options menu area is a Edit Signature listing. Click on that listing.
Clicking Edit Signature opens another page. In the middle of that page is where you Edit YOUR signature.
Enter your information there and at bottom of the window you are entering your signature is button for either Preview Signature or Save Signature. Do save and you will have your signature incorporated into the forum in each of your posts. Of course Preview Signature will let you see 'how' your signature would appear in the forum. But in the end the Save Signature must be clicked to save it to the forum.
You can look at my signature for a template of some good stuffz to put in one's own signature when seeking help.
Good luck man.
Also, I should probably mention that on the very first power on, there was a weird kind of popping noise followed by a smell of something burning. Could that have anything to do with it?
