@ShrimpBrime
The X Ryzens (including TRs) can report negative temps (between -10 and -27, depending on model), but non-X will bottom out at 0, as the temp register holds an unsigned value (can be 0 or positive)
@ShrimpBrime
ShrimpBrime, what do you mean by "once frozen"?
@ShrimpBrime
It's probably the super IO chip's sensors for the temp, not the CPU's built in monitoring system.
Other monitoring software I use reports temps that look reasonable but Realbench's report shows 0c no matter how hard the CPU is working. Why does not Realbench work on this CPU? That's what I'm asking.
it just cant read the sensor/register is what I imagine...Other monitoring software I use reports temps that look reasonable but Realbench's report shows 0c no matter how hard the CPU is working. Why does not Realbench work on this CPU? That's what I'm asking.
