- Thread Starter
- #341
Last question, how do you remove the springs on the bolts, I thought there is something that holds it on....I'll have to tear it apart later
Lol - I discovered it by accident when one of my screws fell loose in my case then got wedged in a spot and I had to tug on it a little. It may have been a bit looser to begin with, but there's just a ridge on the bold that holts the spring on. If you use a pair of pliers or something the springs pop off with a bit of a pull. When you put them back on (say you didn't use washers after all) they'll generally always be a bit looser than before and may fall off the bolt more easily, but it has no effect on their performance (just that when you handle them, if you have a loose one you may have to hold it to keep it from falling off while you position the screw to tighten it down).
