Yes, it will be better because it puts out more heat, but it also requires I re-run all of my previous tests because the absolute temps and deltas will not be comparable between the two.
As for the thermal resistance stuff, I think the electricity analogy explained it fairly well. Fact is, if the die / IHS interface is bad you'll have high temps, but if one cooler works better than another, it should still work better and the temps will reflect that. This should be fairly clear. If the U120X is supposed to beat the Maxorb, it should beat the Maxorb regardless of how much power is dissipated through it, provided that the amount of power dissipated doesn't change between tests. The die / IHS interface isn't going to be bad for the U120X, then magically get better for the Maxorb. So it doesn't explain the Maxorb / U120X comparison w/ the 1st and 2nd heatsink. The 3rd one, because it performs somewhat better, is more up for debate.
what will testing another cpu prove?that his 4400 runs hot?am i missing something here?
i understand what is being asked.what i dont understand is how there is supposed to be a difference between testing a pd or his c2d?how will testing a pd prove anything about the hsf hes tested?
the testbed hasnt changed according to the op.so what is left to debate?
me tinks you guys should just agree to disagree on this one.
im not trying to start a flame war here but it seems like there has been enough proof presented for everyone to just live and let live lol.
The differences on the two processors really wont mean much, however what your really looking for when comparing two heatsinks is the deltaT which is found through your Load Average - ambient temp = dT. That would measure the exact difference between the two heatsinks and how well they perform. I tested the Ultra 120 extreme against a variety of heatsinks, and heres how the numbers stacked up.
the lower the deltaT the better the heatsink performed, as shown by this chart.
it basically removes the variations created in ambient temperature fluctuation's. As you can see by the charts a few of the heatsinks changed ranking positions on the deltaT chart because of the equation. So in order to take the two chips into consideration you would have to have a set of test results for the E4300 and then a set of test results on the Pentium D, however the pentium D's ability to record temps is far less accurate then the E4300, as you can get exact core temperature readings on core 2 duos.
its not really even that... its just to get the heatsink on a different chip as its looking like the c2d chip notlag currently has, has bad contact between the core and IHS, causing bad temps overall... or GOD FORBID, hes doing something wrong... but notlag is perfect so that couldnt be... *cough*thermaltake rep*cough*
how hard is it to put the ultra 120x, put it on the pentium d... run a stress test for like 5 min to see if the ultra 120 works??? then take the ultra 120 off and pop on the max orb... its like your trying all you can to NOT test this right, so you can just say to not buy thermalright products.... thats just what im seeing... dunno if its just me tho.
so I am guessing it's just Notlag's chip that is running hot..
Folks, this doesn't explain the Maxorb and first two U120X's tying, or the third one performing better by a 4C margin.
Actually it does. As someone else stated; the temps of your IHS are limiting the cooling effectiveness of your heatsinks.
<PRE>
R1 R2
R3 |
R1 = heat transfer from die to IHS (low resistance)
R2 = other paths for heat to leave the CPU (high resistance)
R3 = heat transfer from IHS to air through heatsink (low resistance)
R(Total) = 1 / ( (1/(R1 + R3)) + (1/R2) )
</PRE>
Wow, ten pages of absolute nonsense.
Why is this thread still going?
Could you get temp readings with CoreTemp? I have trust issues with TAT.btw at stock it cools amazingly:
IDLE temp: 21c on both cores
LOAD temp: around 31-33c
nice
