Its just an offer, like i said, its up to you if u want it see it compared against what i have here. Let me know if you want to take up on the offer.
Yah, I'll give it some thought. The bigger issue to me is being without a heatsink for the duration and having to put everything off longer. Even if my heatsink ended up doing as well as the test TR U120X in your OCPulse review, I'd be at a complete loss to explain it:
1. Actual air flow within my case is a non-issue because the side panel was removed. Even if the side panel was not on, my case does have negative pressure and the rear fans are close-by to exhaust hot air from the case.
2. High fan inlet air temperature is no longer an issue because I rotated the heatsink (no longer pulling air over the GPU and NB)
3. Have tried various amounts and methods of applying the thermal compound (which isn't rocket science)
4. Air flow over the heatsink is good - I'm using a fairly high output fan that is well regarded (ie - not like a generic fan or TT or something)
5. My original heatsink performed better after lapping the CPU, so I know the CPU was not lapped badly
6. Mounting pressure is more than adequate - I've tried using washers to increase mounting pressure w/ no change
7. Issues w/ the CPU could explain overall high temps, but do
nothing to explain the first two heatsinks essentially performing the same as a Maxorb
Despite this, I'm still looking at delta's of 35C with an E4300 @ 9 x 333MHz, 1.325v
