- Thread Starter
- #241
Ok, so on to the good stuff. Here's a quick recap of the temperatures (I've included the deltas in parenthesis - really the deltas are the real ones people should be comparing because my ambient temps were higher for the 3rd heatsink). The temps were generated using TAT. Based on other tests I've done I think TAT itself reads about 7C high for me across the board, but I haven't factored that in (as I don't think most people have done much to correct for their TAT / CoreTemp temperatures). For those that care, my CPU at the speed / voltage below w/ TAT at 100% produces around 85W of thermal power, giver or take a couple of watts(which I've confirmed by comparing wall-outlet amperage at various speeds).
Core Temperatures - E4300 @ 3GHz, 1.325v, 100% Load
(Difference Between Core Temp and Ambient Temp)
TT Maxorb: 67C (43C) [75F Ambient]
First two TR U120X's: 66C (42C) [75F Ambient - horizontal mounting]
3rd TR U120X: 65C (39C) [78F Ambient - horizontal mounting]
3rd TR U120X: 63C (37C) [78F Ambient - vertical mounting]
Interpret that how you will. The first two TR's barely beat what should have been a much less capable Maxorb. Even if you give them the 2C benefit of the doubt had they been vertically mounted, that's still a narrow win. The 3rd heatsink from Thermalright does do somewhat better, managing temperatures 3C better than the first two.
So were the first two defective? Was the third also but a bit less so (the base was much better, which might account for most of the difference)? Or are the current parts being produced by Thermalright not quite what they're cracked up to be? A Maxorb nearly tied with the first two U120X's and a Tuniq Tower 120 would likely perform about the same as my 3rd U120X (maybe even a touch better, but likely not by much of a margin either way). Bear in mind this is for a dual core system - quad cores might fare a bit better performance from the Thermalrights, but the numbers are hardly earth shattering.
(mounted same way as original tests - horizontally)
(rotated 90 degrees - mounted vertically)
